Introduzione
This guide is for removing the phone's earpiece speaker.
Using a spudger, remove the four rubber covers from over the screws. Using a spudger, remove the four rubber covers from over the screws. Using a spudger, remove the four rubber covers from over the screws.
  • Using a spudger, remove the four rubber covers from over the screws.
Aggiungi Commento
Unscrew the cover screws using the T6 bit
  • Unscrew the cover screws using the T6 bit
Aggiungi Commento
Loosen and remove the cover with a plastic opening tool. Loosen and remove the cover with a plastic opening tool.
  • Loosen and remove the cover with a plastic opening tool.
Aggiungi Commento
Guida ai regali per la festa del papà
Facciamo onore non solo ai nostri padri — festeggiamo tutti i mentori che ci hanno insegnato a riparare.
Facciamo onore a chi ci ha insegnato a riparare.
Gently loosen the protective cover with the plastic opening tool. Gently loosen the protective cover with the plastic opening tool.
  • Gently loosen the protective cover with the plastic opening tool.
Do not pry from the top or bottom of the metal cover. There are a pair of 1/4" long openings on either side of the metal cover at the midpoint of the case. The plastic teeth which lock into the openings must be withdrawn. I used the point of cuticle sissors to get behind the metal strip under each tooth and pull outwards a small distance to release each tooth. The sides of the cover will spring up.
Fonce - Replica
Carefully remove the protective cover from the circuitry Slowly peel the black rubber gasket up off the circuit board. Carefully move the camera out of the way using your hand.
  • Carefully remove the protective cover from the circuitry
  • Slowly peel the black rubber gasket up off the circuit board.
  • Carefully move the camera out of the way using your hand.
  • Use a flat tool to separate the connection between the upper and lower circuit boards.
Aggiungi Commento
Gently slip the copper strip out from under the circutry by hand. Gently slip the copper strip out from under the circutry by hand. Gently slip the copper strip out from under the circutry by hand.
  • Gently slip the copper strip out from under the circutry by hand.
Aggiungi Commento
Pry out the speaker using your fingers. Pry out the speaker using your fingers. Pry out the speaker using your fingers.
  • Pry out the speaker using your fingers.
Aggiungi Commento
Conclusione
gregatron
Membro da: 29/10/2009
72 Reputazione
12 Guide realizzate
Cal Poly, Team 6-6, Maness Fall 2009 Membro di Cal Poly, Team 6-6, Maness Fall 2009
CPSU-MANESS-F09S6G6
4 Membri
12 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 2,578
