Salta al contenuto principale
Motorola V325 midframe replacement
Cosa ti serve
  1. Motorola V325 midframe replacement, Battery: passo 1, immagine 1 di 1
    • Flip the phone over so that the back is visible.
    • Push down on the silver button using your fingernail or thumbnail. Push down all the way until the button stops.
  2. Motorola V325 midframe replacement: passo 2, immagine 1 di 3 Motorola V325 midframe replacement: passo 2, immagine 2 di 3 Motorola V325 midframe replacement: passo 2, immagine 3 di 3
    • While holding down the silver button, simultaneously pull downward on the rear cover, then lift it off to reveal the battery.
    • This will only take a moment to do.
  3. Motorola V325 midframe replacement: passo 3, immagine 1 di 3 Motorola V325 midframe replacement: passo 3, immagine 2 di 3 Motorola V325 midframe replacement: passo 3, immagine 3 di 3
    • Using your thumbnail and fingernail, grip the battery where indicated as "pull here" and lift the battery upward, starting at that side.
    • Remove the battery completely by lifting it straight out of the phone.
  4. Motorola V325 midframe replacement: passo 4, immagine 1 di 1
    • When replacing the battery, ensure that the side that has the "pull here" arrows goes toward the bottom of the phone. Place the side of the battery with the metallic contacts in toward the inside of the phone, making a full connection with the contacts within the phone (shown in the red rectangle).
  5. Motorola V325 midframe replacement, Rear Panel: passo 5, immagine 1 di 3 Motorola V325 midframe replacement, Rear Panel: passo 5, immagine 2 di 3 Motorola V325 midframe replacement, Rear Panel: passo 5, immagine 3 di 3
    • Using a small flat head screwdriver or your fingernail, remove the rubber covers near the top of the phone
  6. Motorola V325 midframe replacement: passo 6, immagine 1 di 3 Motorola V325 midframe replacement: passo 6, immagine 2 di 3 Motorola V325 midframe replacement: passo 6, immagine 3 di 3
    • There are four Torx screws located on the four corners of the rear panel
    • Remove all four screws using the T6 Torx Screwdriver.
  7. Motorola V325 midframe replacement: passo 7, immagine 1 di 3 Motorola V325 midframe replacement: passo 7, immagine 2 di 3 Motorola V325 midframe replacement: passo 7, immagine 3 di 3
    • Unscrew the antenna.
    • Remove the antenna protective tubing
  8. Motorola V325 midframe replacement: passo 8, immagine 1 di 3 Motorola V325 midframe replacement: passo 8, immagine 2 di 3 Motorola V325 midframe replacement: passo 8, immagine 3 di 3
    • There are four light gray tabs located around the phone (two on each side)
    • Using your finger nail or a flat head screwdriver, pull the gray tab away from the body while simultaneously lifting upward on the black rear panel.
    • Once all four tabs are removed, lift up the back panel to reveal the interior logic board.
Linea Traguardo
Adrian Doan
Membro da: 01/19/10
22 Reputazione
2 Guide realizzate
Cal Poly, Team 4-15, Forte Winter 2010 Membro di Cal Poly, Team 4-15, Forte Winter 2010
CPSU-FORTE-W10S4G15
5 Membri
8 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 1,947
