Introduzione
The outer housing can be removed to be cleaned or swapped to a custom housing.
Parti
Nessuna parte richiesta.
Remove the rearmost panel by pushing down on the silver button, then simultaneously pulling downward on the panel. Lift the panel off of the phone. Lift the panel off of the phone.
  • Remove the rearmost panel by pushing down on the silver button, then simultaneously pulling downward on the panel.
  • Lift the panel off of the phone.
Aggiungi Commento
Using your thumbnail or a thin flat head screwdriver, peel back the screen protector on the inside of the phone: It is only held on by glue but may take a good amount of force to be removed. Using your thumbnail or a thin flat head screwdriver, peel back the screen protector on the inside of the phone: It is only held on by glue but may take a good amount of force to be removed. Using your thumbnail or a thin flat head screwdriver, peel back the screen protector on the inside of the phone: It is only held on by glue but may take a good amount of force to be removed.
  • Using your thumbnail or a thin flat head screwdriver, peel back the screen protector on the inside of the phone: It is only held on by glue but may take a good amount of force to be removed.
Aggiungi Commento
MacBook Battery Fix Kits
Fix Kits Starting at $69.99
Starting at $69.99
Unscrew the four screws using the T6 Torx Screwdriver. Unscrew the four screws using the T6 Torx Screwdriver.
  • Unscrew the four screws using the T6 Torx Screwdriver.
Aggiungi Commento
Peel back the screen protector frame. Close phone at the hinge, then pull off the front outer casing. Peel back the screen protector frame. Close phone at the hinge, then pull off the front outer casing. Peel back the screen protector frame. Close phone at the hinge, then pull off the front outer casing.
  • Peel back the screen protector frame. Close phone at the hinge, then pull off the front outer casing.
Aggiungi Commento
Conclusione
Minh Tran
Membro da: 15/01/2010
2 Reputazione
2 Guide realizzate
Cal Poly, Team 4-15, Forte Winter 2010 Membro di Cal Poly, Team 4-15, Forte Winter 2010
CPSU-FORTE-W10S4G15
5 Membri
8 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 2,025
