Introduzione
Replacing the phone's headphone jack.
Parti
Nessuna parte richiesta.
Locate the silver button on the back of the phone, near the bottom.
  • Locate the silver button on the back of the phone, near the bottom.
  • Press down the button with one hand whilst sliding the back cover of the phone away from the antenna.
  • The back cover should slide off easily.
Aggiungi Commento
Insert a plastic spudger near one corner of the battery (preferably one furthest from the phone's antenna).
  • Insert a plastic spudger near one corner of the battery (preferably one furthest from the phone's antenna).
  • With a firm grip, gently lift the end of your tool up. The battery should easily raise out of its place.
  • Now that the battery is exposed, use your fingers to remove the it from the phone.
Aggiungi Commento
Note the metal connections on the phone, which are now exposed with the battery removed. There are corresponding metal connectors on the replacement battery.
  • Note the metal connections on the phone, which are now exposed with the battery removed.
  • There are corresponding metal connectors on the replacement battery.
  • When you install the battery, be sure both connectors are matched up. Otherwise, your battery will be unable to supply power to your phone.
Aggiungi Commento
Use Spudger to remove rubber plug from upper left corner of the back of the phone
  • Use Spudger to remove rubber plug from upper left corner of the back of the phone
Aggiungi Commento
Using a Hex T6 screwdriver, remove the 4 screws holding the back plate of the phone in place
  • Using a Hex T6 screwdriver, remove the 4 screws holding the back plate of the phone in place
Aggiungi Commento
Using your hands, pull up on the back plate while pulling on the 3 side tabs to remove the back plate. Be careful when removing the back plate; don't put too much stress on the back plate or the plastic may snap Be careful when removing the back plate; don't put too much stress on the back plate or the plastic may snap
  • Using your hands, pull up on the back plate while pulling on the 3 side tabs to remove the back plate.
  • Be careful when removing the back plate; don't put too much stress on the back plate or the plastic may snap
Aggiungi Commento
On the back casing, using a spudger, push into the headphone jack at an upward angle to pop it out
  • On the back casing, using a spudger, push into the headphone jack at an upward angle to pop it out
Aggiungi Commento
Conclusione
Jason Kilroy
Membro da: 11/04/2010
1 Reputazione
5 Guide realizzate
Cal Poly, Team 27-96, Amido Spring 2010 Membro di Cal Poly, Team 27-96, Amido Spring 2010
CPSU-AMIDO-S10S27G96
4 Membri
15 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 811
