Introduzione
A guide for replacing or inspecting the Motorola V276 ear speaker
Using the iPod opening tool, place the tool in the small crack that runs along the side of the front case to pry it off
  • Using the iPod opening tool, place the tool in the small crack that runs along the side of the front case to pry it off
Aggiungi Commento
Using the T6 Torx Screwdriver remove all 4 small screws.
  • Using the T6 Torx Screwdriver remove all 4 small screws.
Aggiungi Commento
Remove silver plate from phone.
  • Remove silver plate from phone.
Aggiungi Commento
Using the spudger, remove the plastic camera casing
  • Using the spudger, remove the plastic camera casing
Aggiungi Commento
Pull back the logic board
  • Pull back the logic board
Aggiungi Commento
Underneath the logic board, use your hands or a spudger to remove the ear speaker
  • Underneath the logic board, use your hands or a spudger to remove the ear speaker
Aggiungi Commento
Conclusione
Cal Poly, Team 27-96, Amido Spring 2010 Membro di Cal Poly, Team 27-96, Amido Spring 2010
CPSU-AMIDO-S10S27G96
4 Membri
15 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 1,538
