Introduzione
Use this guide to replace the keypad.
Push down on the black tab located at the top center of the Motorola phone
  • Push down on the black tab located at the top center of the Motorola phone
Aggiungi Commento
Remove the battery by pulling the battery from the top center
  • Remove the battery by pulling the battery from the top center
Aggiungi Commento
Remove the four (4) T6 Torx screws from the rear metal plate.
  • Remove the four (4) T6 Torx screws from the rear metal plate.
Aggiungi Commento
Insert the flat end of a spudger and pry the metal cover up off the phone Insert the flat end of a spudger and pry the metal cover up off the phone
  • Insert the flat end of a spudger and pry the metal cover up off the phone
Aggiungi Commento
Carefully, disconnect the two connectors from their sockets on the motherboard using the flat end of a spudger. Carefully, disconnect the two connectors from their sockets on the motherboard using the flat end of a spudger.
  • Carefully, disconnect the two connectors from their sockets on the motherboard using the flat end of a spudger.
Aggiungi Commento
Use a spudger to pry the antenna cable connectors from its respective socket on the motherboard.
  • Use a spudger to pry the antenna cable connectors from its respective socket on the motherboard.
  • De-route the antenna cable by pulling it out.
Aggiungi Commento
Starting at one side, use a spudger to lift and remove the black plastic screw cover at the bottom of the phone near the speaker
  • Starting at one side, use a spudger to lift and remove the black plastic screw cover at the bottom of the phone near the speaker
  • The cover is attached by several clips, so some force may be required, especially to unclip the first clip.
  • Be careful not to loose the round plastic piece that covers the microphone.
Aggiungi Commento
Remove the 2 newly exposed T6 screws Remove the 2 newly exposed T6 screws
  • Remove the 2 newly exposed T6 screws
Aggiungi Commento
Starting at the top, insert the flat end of a spudger and pry the frame of the phone. The frame is attached by several clips, so some force may be required to dislodge the first clip.
  • Starting at the top, insert the flat end of a spudger and pry the frame of the phone.
  • The frame is attached by several clips, so some force may be required to dislodge the first clip.
  • Work your tool around the entire edge of the phone, moving as soon as you hear a clip come undone, to avoid breaking the frame.
Aggiungi Commento
Carefully, Insert the flat end of a spudger and pry the keyboard up off the phone. Carefully, Insert the flat end of a spudger and pry the keyboard up off the phone.
  • Carefully, Insert the flat end of a spudger and pry the keyboard up off the phone.
Aggiungi Commento
Conclusione
Jorge Trujillo
Membro da: 19/05/2011
471 Reputazione
4 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 7
Tutti i Tempi: 5,250
