Introduzione
This guide will help you replace the upper casing on your device. Following these steps will also enable you to replace the camera.
Parti
Nessuna parte richiesta.
Remove the four rubber pieces from all corners of the area that borders the screen.
  • Remove the four rubber pieces from all corners of the area that borders the screen.
Aggiungi Commento
Use a T4 screwdriver to carefully unscrew all four screws on the outer screen.
  • Use a T4 screwdriver to carefully unscrew all four screws on the outer screen.
  • Be sure that you do not strip or damage the screws.
Aggiungi Commento
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
Carefully pry the screen away from the phone using a plastic spudger.
  • Carefully pry the screen away from the phone using a plastic spudger.
  • Pry slowly, as too much bending will crack the screen. There are also two fragile ribbon cables that connect the screen and camera to the phone.
Aggiungi Commento
Take the screen housing off of the casing. Watch for small pieces falling out of the screen during this step. Keep track of these pieces. Watch for small pieces falling out of the screen during this step. Keep track of these pieces.
  • Take the screen housing off of the casing.
  • Watch for small pieces falling out of the screen during this step. Keep track of these pieces.
Aggiungi Commento
Conclusione
Altre 4 persone hanno completato questa guida.
krisko
Membro da: 14/01/2010
95 Reputazione
4 Guide realizzate
Cal Poly, Team 11-4, Forte Winter 2010 Membro di Cal Poly, Team 11-4, Forte Winter 2010
CPSU-FORTE-W10S11G4
3 Membri
8 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 8
Tutti i Tempi: 4,889
