Salta al contenuto principale
Motorola Razr V3c Speaker (CDMA) Replacement
Cosa ti serve
  1. Motorola Razr V3c Speaker (CDMA) Replacement, Battery (CDMA): passo 1, immagine 1 di 3 Motorola Razr V3c Speaker (CDMA) Replacement, Battery (CDMA): passo 1, immagine 2 di 3 Motorola Razr V3c Speaker (CDMA) Replacement, Battery (CDMA): passo 1, immagine 3 di 3
    • Press down on the the rear panel release button while simultaneously prying the rear panel straight away from the V3c.
    • Lift and remove the rear panel away from the V3c.
  2. Motorola Razr V3c Speaker (CDMA) Replacement: passo 2, immagine 1 di 2 Motorola Razr V3c Speaker (CDMA) Replacement: passo 2, immagine 2 di 2
    • Remove the battery by pushing in the top of the battery and lifting it away from the phone.
  3. Motorola Razr V3c Speaker (CDMA) Replacement, Speaker (CDMA): passo 3, immagine 1 di 1
    • Unscrew the two screws in the back using the T6.
  4. Motorola Razr V3c Speaker (CDMA) Replacement: passo 4, immagine 1 di 1
    • Use the plastic opening tool to pop the bottom and the sides off the back casing.
    • Be careful not to pull the back lower cover off too far as it is connected to the phone body by a ribbon.
  5. Motorola Razr V3c Speaker (CDMA) Replacement: passo 5, immagine 1 di 1
    • Peel off the connector between the motherboard and the body of the phone.
  6. Motorola Razr V3c Speaker (CDMA) Replacement: passo 6, immagine 1 di 2 Motorola Razr V3c Speaker (CDMA) Replacement: passo 6, immagine 2 di 2
    • Pull out the two black rubber covers using tweezers.
    • The second rubber cover is much harder to get out.
  7. Motorola Razr V3c Speaker (CDMA) Replacement: passo 7, immagine 1 di 2 Motorola Razr V3c Speaker (CDMA) Replacement: passo 7, immagine 2 di 2
    • Pull out the white plastic cover by unclipping the two plastic pieces shown.
  8. Motorola Razr V3c Speaker (CDMA) Replacement: passo 8, immagine 1 di 1
    • Pull out the speaker.
Conclusione
Cal Poly, Team 11-4, Forte Winter 2010 Membro di Cal Poly, Team 11-4, Forte Winter 2010
CPSU-FORTE-W10S11G4
3 Membri
8 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 5,424
