Introduzione
This guide will show you how to remove and replace the screen for a Motorola V3c.
Parti
Nessuna parte richiesta.
Remove the four rubber pieces from all corners of the area that borders the screen.
  • Remove the four rubber pieces from all corners of the area that borders the screen.
Aggiungi Commento
Use a T4 screwdriver to carefully unscrew all four screws on the outer screen.
  • Use a T4 screwdriver to carefully unscrew all four screws on the outer screen.
  • Be sure that you do not strip or damage the screws.
Aggiungi Commento
Carefully pry the screen away from the phone using a plastic spudger.
  • Carefully pry the screen away from the phone using a plastic spudger.
  • Pry slowly, as too much bending will crack the screen. There are also two fragile ribbon cables that connect the screen and camera to the phone.
Aggiungi Commento
Take the screen housing off of the casing. Watch for small pieces falling out of the screen during this step. Keep track of these pieces. Watch for small pieces falling out of the screen during this step. Keep track of these pieces.
  • Take the screen housing off of the casing.
  • Watch for small pieces falling out of the screen during this step. Keep track of these pieces.
Aggiungi Commento
Pry screen cover off with plastic spudger. The screen cover has some adhesive holding it to the screen
  • Pry screen cover off with plastic spudger.
  • The screen cover has some adhesive holding it to the screen
Aggiungi Commento
Remove small black sticker covering the camera ribbon connector.
  • Remove small black sticker covering the camera ribbon connector.
Aggiungi Commento
Flip over small hinge that covers the camera ribbon connection.
  • Flip over small hinge that covers the camera ribbon connection.
Aggiungi Commento
Pull off the rubber camera cover and camera. The camera and camera cover may come off either separately or together. The camera and camera cover may come off either separately or together.
  • Pull off the rubber camera cover and camera.
  • The camera and camera cover may come off either separately or together.
Aggiungi Commento
Disconnect the metallic ribbon cover.
  • Disconnect the metallic ribbon cover.
Aggiungi Commento
Remove and replace the screen. Remove and replace the screen.
  • Remove and replace the screen.
Aggiungi Commento
Linea Traguardo
Joshua Ruehlig
Membro da: 14/01/2010
503 Reputazione
4 Guide realizzate
Cal Poly, Team 11-4, Forte Winter 2010 Membro di Cal Poly, Team 11-4, Forte Winter 2010
CPSU-FORTE-W10S11G4
3 Membri
8 Guide realizzate
Is it a T5 or a T4 for removing the screws?
Francis Reyes - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 4
Tutti i Tempi: 8,923
