Introduzione
The purpose of this repair guide is to show how to replace the lower outer casing.
Press down on the the rear panel release button while simultaneously prying the rear panel straight away from the V3c. Lift and remove the rear panel away from the V3c. Lift and remove the rear panel away from the V3c.
  • Press down on the the rear panel release button while simultaneously prying the rear panel straight away from the V3c.
  • Lift and remove the rear panel away from the V3c.
With the phone closed, press the silver button shown with a fingernail or such. Tilt and lift the battery cover and put aside.
walltoall - Replica
Remove the battery by pushing in the top of the battery and lifting it away from the phone. Remove the battery by pushing in the top of the battery and lifting it away from the phone.
  • Remove the battery by pushing in the top of the battery and lifting it away from the phone.
The Motorola V3 battery has a notch in one corner to ensure it can only go in one way. Fit the replacement battery by offering its bottom edge to the device, then tilt and click using thumb pressure.
walltoall - Replica
Unscrew the two screws in the back using the T6.
  • Unscrew the two screws in the back using the T6.
Aggiungi Commento
Use the spudger to pop the bottom  and the sides of the back casing
  • Use the spudger to pop the bottom and the sides of the back casing
  • Be careful not to pull the back lower cover off too far as it is connected to the phone body by a ribbon
Aggiungi Commento
Kit RAM Mac
Accelera il Mac. Porta la memoria al massimo.
Kit RAM Mac
Metti più memoria nel tuo Mac.
Peel off the connector between the motherboard and the body of the phone
  • Peel off the connector between the motherboard and the body of the phone
Aggiungi Commento
Pull out the two black rubber covers using tweezers The second rubber cover is much harder to get out
  • Pull out the two black rubber covers using tweezers
  • The second rubber cover is much harder to get out
Aggiungi Commento
Pull out the white plastic cover by unclipping the two plastic pieces shown Pull out the white plastic cover by unclipping the two plastic pieces shown
  • Pull out the white plastic cover by unclipping the two plastic pieces shown
Aggiungi Commento
Pull out the speaker
  • Pull out the speaker
Aggiungi Commento
Pull out the motherboard. You may also now replace the bottom lower casing
  • Pull out the motherboard.
  • You may also now replace the bottom lower casing
Aggiungi Commento
Unscrew the two screws holding the plastic speaker cover to the phone with a T5 screwdriver
  • Unscrew the two screws holding the plastic speaker cover to the phone with a T5 screwdriver
Aggiungi Commento
Pull off and replace the lower front casing
  • Pull off and replace the lower front casing
  • The metallic grounding grid will come off when the lower front casing is removed
  • Make sure to reinsert the metallic grounding unit when re-screwing the new lower bottom casing
Aggiungi Commento
Conclusione
krisko
Membro da: 14/01/2010
95 Reputazione
4 Guide realizzate
Cal Poly, Team 11-4, Forte Winter 2010 Membro di Cal Poly, Team 11-4, Forte Winter 2010
CPSU-FORTE-W10S11G4
3 Membri
8 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 3
Tutti i Tempi: 6,010
