Introduzione
This guide will show you how to remove and replace the camera for a Motorola V3c.
Strumenti
Parti
Nessuna parte richiesta.
Remove the four rubber-like pieces from all corners of the surrounding area that border the screen.
Use a T4 screwdriver to carefully unscrew all four screws on the outer screen.
Carefully pry the screen open using a plastic spudger.
Take the screen housing off from the casing.
Pry screen cover off with plastic spudger
Remove small black sticker covering the camera ribbon connector
Flip over small hinge that cover the camera ribbon connection
Pull off the rubber camera cover and camera
