When looking at the front of the phone, use the Plastic Opening Tool to pry off the four buttons located in each of the corners on the front.
  • When looking at the front of the phone, use the Plastic Opening Tool to pry off the four buttons located in each of the corners on the front.
Aggiungi Commento
Turn the phone face-down. Remove the back cover, exposing the battery.
  • Turn the phone face-down. Remove the back cover, exposing the battery.
  • Use the Plastic Opening Tool to pry the battery out of the phone.
Aggiungi Commento
Using the appropriate size Phillips screwdriver, unscrew the four screws located in each of the corners on the back of the device.
  • Using the appropriate size Phillips screwdriver, unscrew the four screws located in each of the corners on the back of the device.
  • Although the battery is shown in this picture, please remember to make sure that it is removed in order to proceed with disassembly.
Aggiungi Commento
After removal of the back screws, use the Plastic Opening Tool to carefully separate the top and bottom halves of the device.
  • After removal of the back screws, use the Plastic Opening Tool to carefully separate the top and bottom halves of the device.
Aggiungi Commento
Using the appropriate size Phillips screwdriver, remove any screws that are attached or associated with the keypad and carefully remove keypad from the device.
  • Using the appropriate size Phillips screwdriver, remove any screws that are attached or associated with the keypad and carefully remove keypad from the device.
Aggiungi Commento
On the back of the device, you will see individual green and yellow technical pieces. Remove those two pieces from the phone with your fingers and set aside.
  • On the back of the device, you will see individual green and yellow technical pieces. Remove those two pieces from the phone with your fingers and set aside.
Aggiungi Commento
You should now have all of the pieces separated and disassembled for your device.
  • You should now have all of the pieces separated and disassembled for your device.
Aggiungi Commento
On the front of the device, pry off the top right, top left, bottom right, and bottom left buttons
  • On the front of the device, pry off the top right, top left, bottom right, and bottom left buttons
Aggiungi Commento
On the back of the device unscrew the top right, top left, bottom right, and bottom left buttons using appropriate size Phillips screwdriver
  • On the back of the device unscrew the top right, top left, bottom right, and bottom left buttons using appropriate size Phillips screwdriver
Aggiungi Commento
Once screws are dismantled, use plastic opening tool to assist separation of the top half of device from the bottom half
  • Once screws are dismantled, use plastic opening tool to assist separation of the top half of device from the bottom half
Aggiungi Commento
Unscrew the screws around the keypad and take apart slowly and gently using your hands
  • Unscrew the screws around the keypad and take apart slowly and gently using your hands
Aggiungi Commento
Conclusione
Rich
Membro da: 08/04/2013
101 Reputazione
6 Guide realizzate
SUNY Cortland, Team 1-4, Getto Spring 2013 Membro di SUNY Cortland, Team 1-4, Getto Spring 2013
SUNYCORT-GETTO-S13S1G4
4 Membri
6 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 245
