Introduzione
Use this guide to replace the midframe on your Photon 4G.
Insert a plastic opening tool into the indentation at the bottom of the phone between the front and rear covers. Lift the back cover from the bottom and remove it from the phone.
  • Insert a plastic opening tool into the indentation at the bottom of the phone between the front and rear covers.
  • Lift the back cover from the bottom and remove it from the phone.
Aggiungi Commento
Insert a plastic opening tool, or your finger, into the notch in between the sim card and the battery and lift the battery upward. Remove the battery from your phone.
  • Insert a plastic opening tool, or your finger, into the notch in between the sim card and the battery and lift the battery upward.
  • Remove the battery from your phone.
Aggiungi Commento
Remove all five screw covers with tweezers located in the picture. Remove all five screw covers with tweezers located in the picture. Remove all five screw covers with tweezers located in the picture.
  • Remove all five screw covers with tweezers located in the picture.
Aggiungi Commento
Remove the 10 T4 Torx screws securing the midframe to the display assembly. Gently pry the midframe from the display assembly and remove it. Gently pry the midframe from the display assembly and remove it.
  • Remove the 10 T4 Torx screws securing the midframe to the display assembly.
  • Gently pry the midframe from the display assembly and remove it.
Aggiungi Commento
Conclusione
Eddie Krause
Membro da: 07/10/2014
262 Reputazione
3 Guide realizzate
USF Tampa, Team 8-6, Leahy Fall 2014 Membro di USF Tampa, Team 8-6, Leahy Fall 2014
USFT-LEAHY-F14S8G6
3 Membri
5 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 182
