Salta al contenuto principale
Motorola Photon 4G MB855 Headphone Jack Replacement
Cosa ti serve
  1. Motorola Photon 4G MB855 Headphone Jack Replacement, Removing the Back Cover: passo 1, immagine 1 di 2 Motorola Photon 4G MB855 Headphone Jack Replacement, Removing the Back Cover: passo 1, immagine 2 di 2
    • Insert a plastic opening tool into the indentation at the bottom of the phone between the front and rear covers.
    • Lift the back cover from the bottom and remove it from the phone.
  2. Motorola Photon 4G MB855 Headphone Jack Replacement, Removing the Battery: passo 2, immagine 1 di 2 Motorola Photon 4G MB855 Headphone Jack Replacement, Removing the Battery: passo 2, immagine 2 di 2
    • Insert a plastic opening tool, or your finger, into the notch in between the sim card and the battery and lift the battery upward.
    • Remove the battery from your phone.
  3. Motorola Photon 4G MB855 Headphone Jack Replacement, Removing Screw Covers: passo 3, immagine 1 di 3 Motorola Photon 4G MB855 Headphone Jack Replacement, Removing Screw Covers: passo 3, immagine 2 di 3 Motorola Photon 4G MB855 Headphone Jack Replacement, Removing Screw Covers: passo 3, immagine 3 di 3
    • Remove all five screw covers with tweezers located in the picture.
  4. Motorola Photon 4G MB855 Headphone Jack Replacement, Removing the Midframe: passo 4, immagine 1 di 3 Motorola Photon 4G MB855 Headphone Jack Replacement, Removing the Midframe: passo 4, immagine 2 di 3 Motorola Photon 4G MB855 Headphone Jack Replacement, Removing the Midframe: passo 4, immagine 3 di 3
    • Remove the 10 T4 Torx screws securing the midframe to the display assembly.
    • Gently pry the midframe from the display assembly and remove it.
  5. Motorola Photon 4G MB855 Headphone Jack Replacement, Locating Headphone Jack: passo 5, immagine 1 di 1
    • Locate Headphone Jack attached to Midframe.
  6. Motorola Photon 4G MB855 Headphone Jack Replacement, Removing Headphone Jack: passo 6, immagine 1 di 3 Motorola Photon 4G MB855 Headphone Jack Replacement, Removing Headphone Jack: passo 6, immagine 2 di 3 Motorola Photon 4G MB855 Headphone Jack Replacement, Removing Headphone Jack: passo 6, immagine 3 di 3
    • Use Tweezers to gently remove Headphone Jack from the Midframe.
    • The Headphone Jack is attached with adhesive, remove carefully.
Conclusione
Eddie Krause
Membro da: 10/07/14
260 Reputazione
3 Guide realizzate
USF Tampa, Team 8-6, Leahy Fall 2014 Membro di USF Tampa, Team 8-6, Leahy Fall 2014
USFT-LEAHY-F14S8G6
3 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 313
