Salta al contenuto principale
Motorola Photon 4G MB855 Battery Replacement
Cosa ti serve
  1. Motorola Photon 4G MB855 Battery Replacement, Removing the Back Cover: passo 1, immagine 1 di 2 Motorola Photon 4G MB855 Battery Replacement, Removing the Back Cover: passo 1, immagine 2 di 2
    • Insert a plastic opening tool into the indentation at the bottom of the phone between the front and rear covers.
    • Lift the back cover from the bottom and remove it from the phone.
  2. Motorola Photon 4G MB855 Battery Replacement, Removing the Battery: passo 2, immagine 1 di 2 Motorola Photon 4G MB855 Battery Replacement, Removing the Battery: passo 2, immagine 2 di 2
    • Insert a plastic opening tool, or your finger, into the notch in between the sim card and the battery and lift the battery upward.
    • Remove the battery from your phone.
Conclusione
Altre 4 persone hanno completato questa guida.
USF Tampa, Team 8-6, Leahy Fall 2014 Membro di USF Tampa, Team 8-6, Leahy Fall 2014
USFT-LEAHY-F14S8G6
3 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 12
Tutti i Tempi: 1,348
