Remove the back cover by sliding the clip and lifting up the bottom of the cover.
  • Remove the back cover by sliding the clip and lifting up the bottom of the cover.
Aggiungi Commento
Remove screws 1 through 4. Remove screws 1 through 4.
  • Remove screws 1 through 4.
Aggiungi Commento
Once all four screws are removed, you should be able to pop off the back half of the phone.
  • Once all four screws are removed, you should be able to pop off the back half of the phone.
Aggiungi Commento
Flip the logic board up to reveal the back of the keypad.
  • Flip the logic board up to reveal the back of the keypad.
Aggiungi Commento
Peal the back of the keypad off of the phone. (Highlighted area are the parts where you can begin to peal from). That white pad is what is being replaced.
  • Peal the back of the keypad off of the phone. (Highlighted area are the parts where you can begin to peal from). That white pad is what is being replaced.
Aggiungi Commento
Take your new key pad and line the holes up with the pegs sticking out of the phone. (Pegs are highlighted).
  • Take your new key pad and line the holes up with the pegs sticking out of the phone. (Pegs are highlighted).
  • Secure the rest of the key pad.
Aggiungi Commento
Put the logic board back into place and reattach cable number 1.
  • Put the logic board back into place and reattach cable number 1.
Aggiungi Commento
Snap the front and back of the phone back together and reinsert screws 1 through 4.
  • Snap the front and back of the phone back together and reinsert screws 1 through 4.
Aggiungi Commento
Conclusione
Danielle Matthews
Membro da: 17/10/2014
13 Reputazione
3 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 59
