Introduzione
This repair guide shows you how to remove the camera so it can be fixed or replaced.
Parti
Nessuna parte richiesta.
Use the Push Pin to remove the rubber screw covers by pushing the needle into the rubber and pulling up.
  • Use the Push Pin to remove the rubber screw covers by pushing the needle into the rubber and pulling up.
  • Be careful not to poke yourself when handling the push pin because it is very sharp.
Aggiungi Commento
Use the T6 screwdriver to remove the four screws holding the casing together.
  • Use the T6 screwdriver to remove the four screws holding the casing together.
  • Note: they are in the same place where you removed the four rubber coverings
Aggiungi Commento
Wedge the plastic opening tool in between the top and bottom cases. This may require a little or a lot of force so be careful. Note: the phone should be face up and the plastic opening tool should be face downwards
  • Wedge the plastic opening tool in between the top and bottom cases. This may require a little or a lot of force so be careful.
  • Note: the phone should be face up and the plastic opening tool should be face downwards
  • Once you get the plastic opening tool in, slide it across the side of the phone, making sure to keep the plastic opening tool wedged in between the two casings.
  • Repeat the 3 steps above for the top, bottom, and opposite side.
Aggiungi Commento
Gently lift and remove the back casing. Gently lift and remove the back casing.
  • Gently lift and remove the back casing.
Aggiungi Commento
Remove the plastic inner cover by placing the spudger under the left-most side and pry to the left and upwards. Gently rotate/wiggle the cover until you can pull it off the phone.
  • Remove the plastic inner cover by placing the spudger under the left-most side and pry to the left and upwards.
  • Gently rotate/wiggle the cover until you can pull it off the phone.
Aggiungi Commento
Using your fingers, remove the plastic piece that holds the camera in place. Using your fingers, remove the plastic piece that holds the camera in place.
  • Using your fingers, remove the plastic piece that holds the camera in place.
Aggiungi Commento
Carefully pry up the upper circuit board with the spudger. The second picture shows what your phone should look like when the upper circuit board is removed.
  • Carefully pry up the upper circuit board with the spudger.
  • The second picture shows what your phone should look like when the upper circuit board is removed.
Aggiungi Commento
Take out the camera and attached chip with the iPod removal tool.  Carefully pry the chip off its connection and the camera will come out too. Take out the camera and attached chip with the iPod removal tool.  Carefully pry the chip off its connection and the camera will come out too.
  • Take out the camera and attached chip with the iPod removal tool. Carefully pry the chip off its connection and the camera will come out too.
Aggiungi Commento
Conclusione
Dave Uth
Membro da: 20/01/2010
35 Reputazione
1 Guida realizzata
Cal Poly, Team 16-33, Maness Winter 2010 Membro di Cal Poly, Team 16-33, Maness Winter 2010
CPSU-MANESS-W10S16G33
4 Membri
5 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 1,843
