Introduzione
This guide will show you step-by-step how to replace the back casing.
Use the Push Pin to remove the rubber screw covers by pushing the needle into the rubber and pulling up.
  • Use the Push Pin to remove the rubber screw covers by pushing the needle into the rubber and pulling up.
  • Be careful not to poke yourself when handling the push pin because it is very sharp.
Aggiungi Commento
Use the T6 screwdriver to remove the four screws holding the casing together.
  • Use the T6 screwdriver to remove the four screws holding the casing together.
  • Note: they are in the same place where you removed the four rubber coverings
Aggiungi Commento
Wedge the plastic opening tool in between the top and bottom cases. This may require a little or a lot of force so be careful. Note: the phone should be face up and the plastic opening tool should be face downwards
  • Wedge the plastic opening tool in between the top and bottom cases. This may require a little or a lot of force so be careful.
  • Note: the phone should be face up and the plastic opening tool should be face downwards
  • Once you get the plastic opening tool in, slide it across the side of the phone, making sure to keep the plastic opening tool wedged in between the two casings.
  • Repeat the 3 steps above for the top, bottom, and opposite side.
Aggiungi Commento
Gently lift and remove the back casing. Gently lift and remove the back casing.
  • Gently lift and remove the back casing.
Aggiungi Commento
Conclusione
Luis Herrera
Membro da: 21/01/2010
52 Reputazione
4 Guide realizzate
Cal Poly, Team 16-33, Maness Winter 2010 Membro di Cal Poly, Team 16-33, Maness Winter 2010
CPSU-MANESS-W10S16G33
4 Membri
5 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 5,000
