Salta al contenuto principale
Motorola Moto G5 Rear Facing Camera Replacement
Cosa ti serve
  1. Motorola Moto G5 Rear Facing Camera Replacement, Back Cover: passo 1, immagine 1 di 2 Motorola Moto G5 Rear Facing Camera Replacement, Back Cover: passo 1, immagine 2 di 2
    • Insert your fingernail or the flat end of a spudger into the notch on the bottom edge of the phone near the charging port.
    • Pry with your fingernail or twist the spudger to release the back cover from the phone.
  2. Motorola Moto G5 Rear Facing Camera Replacement: passo 2, immagine 1 di 3 Motorola Moto G5 Rear Facing Camera Replacement: passo 2, immagine 2 di 3 Motorola Moto G5 Rear Facing Camera Replacement: passo 2, immagine 3 di 3
    • Insert the flat end of a spudger into the seam and slide it along the bottom edge to release the clips holding the back cover to the phone.
  3. Motorola Moto G5 Rear Facing Camera Replacement: passo 3, immagine 1 di 3 Motorola Moto G5 Rear Facing Camera Replacement: passo 3, immagine 2 di 3 Motorola Moto G5 Rear Facing Camera Replacement: passo 3, immagine 3 di 3
    • Continue sliding the flat end of the spudger along the seam for the remaining sides of the phone.
  4. Motorola Moto G5 Rear Facing Camera Replacement: passo 4, immagine 1 di 2 Motorola Moto G5 Rear Facing Camera Replacement: passo 4, immagine 2 di 2
    • Lift the back cover and remove it from the phone.
    • To reinstall the back cover, align the cover with the phone and squeeze along the edges to snap the clips back into place.
  5. Motorola Moto G5 Rear Facing Camera Replacement, Battery: passo 5, immagine 1 di 2 Motorola Moto G5 Rear Facing Camera Replacement, Battery: passo 5, immagine 2 di 2
    • Insert your fingernail or the flat end of the spudger into the notch below the battery.
    • Pry with your fingernail or spudger until you free the battery from its recess.
  6. Motorola Moto G5 Rear Facing Camera Replacement: passo 6, immagine 1 di 1
    • Remove the battery.
    • When installing the battery, make sure the battery's contacts line up with the three gold pins on the top right.
  7. Motorola Moto G5 Rear Facing Camera Replacement, Rear Facing Camera: passo 7, immagine 1 di 2 Motorola Moto G5 Rear Facing Camera Replacement, Rear Facing Camera: passo 7, immagine 2 di 2
    • Remove the eight (8) 4mm screws with a Phillips screwdriver.
  8. Motorola Moto G5 Rear Facing Camera Replacement: passo 8, immagine 1 di 3 Motorola Moto G5 Rear Facing Camera Replacement: passo 8, immagine 2 di 3 Motorola Moto G5 Rear Facing Camera Replacement: passo 8, immagine 3 di 3
    • Pry the top motherboard cover off using a plastic opening tool.
    • When prying it open, make sure to pry it around evenly so that the cover will not snap. This will require some force.
  9. Motorola Moto G5 Rear Facing Camera Replacement: passo 9, immagine 1 di 3 Motorola Moto G5 Rear Facing Camera Replacement: passo 9, immagine 2 di 3 Motorola Moto G5 Rear Facing Camera Replacement: passo 9, immagine 3 di 3
    • Disconnect the marked connector with a pair of tweezers and remove the camera piece.
Conclusione
Altre 3 persone hanno completato questa guida.
Kristina Tran
Membro da: 01/24/18
559 Reputazione
2 Guide realizzate
Cal Poly, Team S2-G3, Livingston Winter 2018 Membro di Cal Poly, Team S2-G3, Livingston Winter 2018
CPSU-LIVINGSTON-W18S2G3
4 Membri
16 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 8
Tutti i Tempi: 1,724
