Salta al contenuto principale
Motorola Moto G Power (2021) Frameless LCD Replacement
Cosa ti serve
  1. Motorola Moto G Power (2021) Frameless LCD Replacement, LCD (Frameless): passo 1, immagine 1 di 2 Motorola Moto G Power (2021) Frameless LCD Replacement, LCD (Frameless): passo 1, immagine 2 di 2
    • Heat up the back of the G Power with a heat gun or iOpener
    • Once the adhesive has softened, insert an opening pick and slide it carefully around the perimeter of the phone to open it.
    • Do not apply too much heat or pressure when prying. You risk bending the plastic back cover.
  2. Motorola Moto G Power (2021) Frameless LCD Replacement, remove plastic cover: passo 2, immagine 1 di 1
    • Remove the 19 Phillips screws shown on the midframe.
  3. Motorola Moto G Power (2021) Frameless LCD Replacement: passo 3, immagine 1 di 3 Motorola Moto G Power (2021) Frameless LCD Replacement: passo 3, immagine 2 di 3 Motorola Moto G Power (2021) Frameless LCD Replacement: passo 3, immagine 3 di 3
    • Use a prying tool to open up the plastic cover plates.
    • If you're using a Jimmy or other metal tool, be careful to not mar the plastic.
  4. Motorola Moto G Power (2021) Frameless LCD Replacement, Removing battery: passo 4, immagine 1 di 3 Motorola Moto G Power (2021) Frameless LCD Replacement, Removing battery: passo 4, immagine 2 di 3 Motorola Moto G Power (2021) Frameless LCD Replacement, Removing battery: passo 4, immagine 3 di 3
    • Unplug the battery connector with a spudger
    • Apply 100% isopropyl alcohol to the edges of the battery. Wait one minute to let the alcohol loosen the adhesive.
    • Pry the battery up carefully. Remove & set aside.
  5. Motorola Moto G Power (2021) Frameless LCD Replacement, remove lcd: passo 5, immagine 1 di 3 Motorola Moto G Power (2021) Frameless LCD Replacement, remove lcd: passo 5, immagine 2 di 3 Motorola Moto G Power (2021) Frameless LCD Replacement, remove lcd: passo 5, immagine 3 di 3
    • heat lcd(can use decent amount of heat to remove)
    • insert opening tool and slide around the perimeter of the LCD to slice the adhesive
    • clean off old adhesive, then apply new glue(either double sided sticky tape or adhesive)
  6. Motorola Moto G Power (2021) Frameless LCD Replacement: passo 6, immagine 1 di 3 Motorola Moto G Power (2021) Frameless LCD Replacement: passo 6, immagine 2 di 3 Motorola Moto G Power (2021) Frameless LCD Replacement: passo 6, immagine 3 di 3
    • plug in new LCD cable
    • insert battery and plug in the battery connector
  7. Motorola Moto G Power (2021) Frameless LCD Replacement, put phone back together: passo 7, immagine 1 di 1
    • put plastic covers on and screw them in
    • remove most of the old adhesive
    • apply either double sided sticky tape or adhesive glue and put the plastic back cover on
    • if it is not sitting well try to heat it up and press it in a phone press or in between heavy books
Conclusione
You did it!
Altre 2 persone hanno completato questa guida.
ryley niemi
Membro da: 02/05/21
259 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 19
Ultimi 30 Giorni: 108
Tutti i Tempi: 2,781
