Use the plastic opening tool to pull peel back screen cover. Gently peel back the screen cover from the speaker slit. Using the T6 Torx-screwdriver, remove the four 4.3 mm screws from the top panel.
  • Use the plastic opening tool to pull peel back screen cover.
  • Gently peel back the screen cover from the speaker slit.
  • Using the T6 Torx-screwdriver, remove the four 4.3 mm screws from the top panel.
Aggiungi Commento
Using the flat end of the plastic opening tool, insert it underneath the plastic cover on the top right corner. Move the opening tool around the phone counter clockwise. Pop the plastic cover off by twisting the plastic covering tool.
  • Using the flat end of the plastic opening tool, insert it underneath the plastic cover on the top right corner.
  • Move the opening tool around the phone counter clockwise.
  • Pop the plastic cover off by twisting the plastic covering tool.
Aggiungi Commento
Using a flat head screwdriver, insert it between the metal logic board casing and the top portion of the phone Move the plastic opening tool around the phone until part of the casting is popped off.
  • Using a flat head screwdriver, insert it between the metal logic board casing and the top portion of the phone
  • Move the plastic opening tool around the phone until part of the casting is popped off.
  • You will need to pop in the four plastic fasteners individually from the metal casing to remove it
  • Be careful not to rip the cable ribbons that are attached to the logic board and casing
Aggiungi Commento
Use the flat end of the plastic opening tool to unclip the cable ribbon from the logic board
  • Use the flat end of the plastic opening tool to unclip the cable ribbon from the logic board
Aggiungi Commento
You now have the top panel completely detached.
  • You now have the top panel completely detached.
Aggiungi Commento
Flip the top portion of the phone so that the back is facing you. Using the flat end of the plastic opening tool, pry the speaker off the back of the phone.
  • Flip the top portion of the phone so that the back is facing you.
  • Using the flat end of the plastic opening tool, pry the speaker off the back of the phone.
Aggiungi Commento
Conclusione
Roberta Glenn
Membro da: 11/07/2012
34 Reputazione
8 Guide realizzate
Cal Poly, Team 1-3, Regan SU 2012 Membro di Cal Poly, Team 1-3, Regan SU 2012
CPSU-REGAN-SU12S1G3
2 Membri
14 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 1,457
