Introduzione
Replace the main logic board for your Motorola MOTO phone.
Parti
Nessuna parte richiesta.
Using your finger, press down on the clip holding the back cover on Pull the back cover off.
  • Using your finger, press down on the clip holding the back cover on
  • Pull the back cover off.
Aggiungi Commento
Place thumb and index finger in the spaces on either side of the battery. Pull battery out.
  • Place thumb and index finger in the spaces on either side of the battery.
  • Pull battery out.
Aggiungi Commento
Using the T5 Torx-screwdriver, remove the four 5.5 mm screws on the back panel.
  • Using the T5 Torx-screwdriver, remove the four 5.5 mm screws on the back panel.
Aggiungi Commento
Using a plastic opening tool, carefully peel back the rubber strip located at the bottom of the keypad Remove the two T5 Torx-screws underneath the rubber strip using the T5 Torx-screwdriver
  • Using a plastic opening tool, carefully peel back the rubber strip located at the bottom of the keypad
  • Remove the two T5 Torx-screws underneath the rubber strip using the T5 Torx-screwdriver
Aggiungi Commento
Using the flat end of the plastic opening tool, insert it in the gap between the charging port and plastic at the bottom left side of the phone. Slide the opening tool around the phone clockwise until you reach the audio port. Twist the opening tool until the plastic pops off from the body of the phone. This make require a small amount of force.
  • Using the flat end of the plastic opening tool, insert it in the gap between the charging port and plastic at the bottom left side of the phone.
  • Slide the opening tool around the phone clockwise until you reach the audio port.
  • Twist the opening tool until the plastic pops off from the body of the phone. This make require a small amount of force.
Aggiungi Commento
Remove the plastic covering completely from the body of the phone.
  • Remove the plastic covering completely from the body of the phone.
Aggiungi Commento
Using the plastic opening tool, carefully unclip the cable ribbon from the main logic board. Be sure not to tear it because the flex is very fragile. Remove the main logic board.
  • Using the plastic opening tool, carefully unclip the cable ribbon from the main logic board. Be sure not to tear it because the flex is very fragile.
  • Remove the main logic board.
Aggiungi Commento
Conclusione
C Miller
Membro da: 25/06/2012
38 Reputazione
6 Guide realizzate
Cal Poly, Team 1-3, Regan SU 2012 Membro di Cal Poly, Team 1-3, Regan SU 2012
CPSU-REGAN-SU12S1G3
2 Membri
14 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 4
Tutti i Tempi: 1,271
