Introduzione
This guide will provide the steps on how to disassemble a broken or cracked LCD(Liquid Crystal Display) screen for the Motorola K1m cellphone. It will also give you the instructions to replace the broken LCD screen with a new and working one. Once you finish this guide you will have a new working LCD screen.
  • Begin by removing the trim piece from around the front face plate.
  • Be very careful when dealing with the trim. It is very delicate, so be cautious when approching this next part.
  • Using your fingers or The Spudger get underneath the trim. Start by applying enough force to pry the trim off.
  • Be patient when trying to pry off the trim. The tape attaching the trim to the phone is very strong. Just be persistent and patient and it will eventually give.
  • Remove the trim piece.
Aggiungi Commento
Once you have removed the trim you will see 4 gold screws at the corners of the phone. Using a T5 Torx Screwdriver, remove the screws. Once you have removed the trim you will see 4 gold screws at the corners of the phone. Using a T5 Torx Screwdriver, remove the screws.
  • Once you have removed the trim you will see 4 gold screws at the corners of the phone. Using a T5 Torx Screwdriver, remove the screws.
markers not working!!!
Deip Paul - Replica
  • Gently use The Spudger towards the edge of the phone and lift the face plate off.
  • The touch-sensitive keys and chip board/LCD screen (which is green) may remain attached to the face plate because of the glue.
  • Gently hold the green logic board down as you lift the face plate apart from it.
  • Remove the face plate.
Aggiungi Commento
Gently, with your fingers or a tweezer, lift the orange flex cable apart from the pin connector it is connected to. Gently remove the green logic board/LCD (Liquid Crystal Display) screen away from the phone. Replace with new green logic board/LCD screen.
  • Gently, with your fingers or a tweezer, lift the orange flex cable apart from the pin connector it is connected to.
  • Gently remove the green logic board/LCD (Liquid Crystal Display) screen away from the phone.
  • Replace with new green logic board/LCD screen.
  • To reassemble the phone, follow of the steps in reverse order.
markers not working
Deip Paul - Replica
Conclusione
Altre 2 persone hanno completato questa guida.
Cal Poly, Team 11-1, Forte Winter 2010 Membro di Cal Poly, Team 11-1, Forte Winter 2010
CPSU-FORTE-W10S11G1
5 Membri
6 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 6,260
