Introduzione
If the inside screen of your Motorola E815 is cracked or broken, you may need to replace it. In this guide you will:
- Dissemble the phone to access the screen
Cosa ti serve
Locate the antenna port on the top of the phone.
Locate the two screws on the backside of the phone.
Unscrew the two screws using your T6 screwdriver.
Grasp the top of the phone near the speaker.
Gently pull the top section of the phone upwards until you feel some resistance.
Locate the brown connector that runs from the top section of the phone to the circuit board under the keypad.
Using tweezers, gently pry the connector from the circuit board.
Detach the top section of the phone from the keypad section.
