Introduzione
When the E815 becomes unresponsive, removing and replacing the battery is often the first and best solution.
To replace the battery, you are going to:
  • Remove back cover
  • Remove Battery
  • Replace Battery
Locate the back cover release slide.
  • Locate the back cover release slide.
  • Use your finger to slide it down.
Aggiungi Commento
Remove the back cover by pulling it away from the phone.
  • Remove the back cover by pulling it away from the phone.
Aggiungi Commento
Locate the battery removal slot. Use your finger to pull the battery out from the top.
  • Locate the battery removal slot.
  • Use your finger to pull the battery out from the top.
  • Remove the battery.
Aggiungi Commento
Conclusione
Altre 2 persone hanno completato questa guida.
Zoie E
Membro da: 12/01/2011
595 Reputazione
5 Guide realizzate
Cal Poly, Team 14-8, Forte Winter 2011 Membro di Cal Poly, Team 14-8, Forte Winter 2011
CPSU-FORTE-W11S14G8
5 Membri
5 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 9
Tutti i Tempi: 3,143
