Introduzione
If you are experiencing trouble with your battery and need to replace it, follow this the guide.
Locate the power button at the top of the phone.  Depress power button for 2 seconds until a menu appears. Locate the power button at the top of the phone.  Depress power button for 2 seconds until a menu appears.
  • Locate the power button at the top of the phone. Depress power button for 2 seconds until a menu appears.
Aggiungi Commento
Once the menu appears, select the "power off" option.  Wait until the phone is completely off. Once the menu appears, select the "power off" option.  Wait until the phone is completely off.
  • Once the menu appears, select the "power off" option. Wait until the phone is completely off.
Aggiungi Commento
Place thumb on the back cover, and push down towards the bottom of the device.  Once the cover releases, pull it away from the phone and set it aside. Place thumb on the back cover, and push down towards the bottom of the device.  Once the cover releases, pull it away from the phone and set it aside.
  • Place thumb on the back cover, and push down towards the bottom of the device. Once the cover releases, pull it away from the phone and set it aside.
Aggiungi Commento
Find the yellow pull tab located in the upper left corner.  Pull the tab until the battery dislodges. Grab the battery by the raised edge, and remove it from the case. Find the yellow pull tab located in the upper left corner.  Pull the tab until the battery dislodges. Grab the battery by the raised edge, and remove it from the case.
  • Find the yellow pull tab located in the upper left corner. Pull the tab until the battery dislodges. Grab the battery by the raised edge, and remove it from the case.
Aggiungi Commento
The battery has been successfully removed.
  • The battery has been successfully removed.
Aggiungi Commento
Conclusione
Altre 4 persone hanno completato questa guida.
Alfred Rosen
Membro da: 04/10/2012
91 Reputazione
1 Guida realizzata
Cal Poly, Team 18-40, Regan Fall 2012 Membro di Cal Poly, Team 18-40, Regan Fall 2012
CPSU-REGAN-F12S18G40
3 Membri
5 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 28
Tutti i Tempi: 3,358
