Salta al contenuto principale
Motorola Droid Turbo Rear Facing Camera Replacement
Cosa ti serve
  1. Motorola Droid Turbo Rear Facing Camera Replacement, Rear Case: passo 1, immagine 1 di 1
    • Prepare an iOpener and lay it over the rear case to soften the adhesive on securing the rear case to the phone.
  2. Motorola Droid Turbo Rear Facing Camera Replacement: passo 2, immagine 1 di 2 Motorola Droid Turbo Rear Facing Camera Replacement: passo 2, immagine 2 di 2
    • Use a plastic opening tool to pry the rear case off of the rest of the device.
    • Remove the rear case.
    • The wireless charging coil may try to stick to the rear case, so make sure to remove it from the case before fully separating the rear case from the rest of the device.
  3. Motorola Droid Turbo Rear Facing Camera Replacement, Midframe: passo 3, immagine 1 di 1
    • Remove the midframe bezel.
  4. Motorola Droid Turbo Rear Facing Camera Replacement: passo 4, immagine 1 di 1
    • Remove the four Torx T5 screws securing the midframe plate.
  5. Motorola Droid Turbo Rear Facing Camera Replacement: passo 5, immagine 1 di 1
    • Remove the midframe.
  6. Motorola Droid Turbo Rear Facing Camera Replacement, Battery: passo 6, immagine 1 di 2 Motorola Droid Turbo Rear Facing Camera Replacement, Battery: passo 6, immagine 2 di 2
    • Use the point of a spudger to pop up the battery connector.
  7. Motorola Droid Turbo Rear Facing Camera Replacement: passo 7, immagine 1 di 2 Motorola Droid Turbo Rear Facing Camera Replacement: passo 7, immagine 2 di 2
    • Fold the wireless charging coil away from the battery.
  8. Motorola Droid Turbo Rear Facing Camera Replacement: passo 8, immagine 1 di 2 Motorola Droid Turbo Rear Facing Camera Replacement: passo 8, immagine 2 di 2
    • Use a spudger to gently pry the battery up from the rest of the device.
    • The battery is secured with some moderate adhesive, so some force may be necessary.
  9. Motorola Droid Turbo Rear Facing Camera Replacement, Rear Facing Camera: passo 9, immagine 1 di 1
    • Remove the four Torx T5 screws securing the lower antenna board to the motherboard.
  10. Motorola Droid Turbo Rear Facing Camera Replacement: passo 10, immagine 1 di 2 Motorola Droid Turbo Rear Facing Camera Replacement: passo 10, immagine 2 di 2
    • Remove the lower antenna board.
  11. Motorola Droid Turbo Rear Facing Camera Replacement: passo 11, immagine 1 di 2 Motorola Droid Turbo Rear Facing Camera Replacement: passo 11, immagine 2 di 2
    • Remove the SIM card holder/volume button rocker.
  12. Motorola Droid Turbo Rear Facing Camera Replacement: passo 12, immagine 1 di 2 Motorola Droid Turbo Rear Facing Camera Replacement: passo 12, immagine 2 di 2
    • Carefully lift up the motherboard to expose the display connector.
  13. Motorola Droid Turbo Rear Facing Camera Replacement: passo 13, immagine 1 di 2 Motorola Droid Turbo Rear Facing Camera Replacement: passo 13, immagine 2 di 2
    • Use the flat end of a spudger to flip up the retaining flap on the display ZIF connector.
    • Pull the display ribbon cable free of the connector.
    • Disconnecting the display ribbon cable makes it easier to remove the rear-facing camera, but it is not strictly necessary.
  14. Motorola Droid Turbo Rear Facing Camera Replacement: passo 14, immagine 1 di 2 Motorola Droid Turbo Rear Facing Camera Replacement: passo 14, immagine 2 di 2
    • Use the flat end of a spudger to flip up the black retaining flap on the front-facing camera ZIF connector.
    • Removing the front-facing camera makes it easier to remove the rear-facing camera, but it is not strictly necessary.
  15. Motorola Droid Turbo Rear Facing Camera Replacement: passo 15, immagine 1 di 2 Motorola Droid Turbo Rear Facing Camera Replacement: passo 15, immagine 2 di 2
    • Remove the front-facing camera.
  16. Motorola Droid Turbo Rear Facing Camera Replacement: passo 16, immagine 1 di 2 Motorola Droid Turbo Rear Facing Camera Replacement: passo 16, immagine 2 di 2
    • Use the flat end of a spudger to flip up the tan retaining flap on the rear-facing camera ZIF connector.
  17. Motorola Droid Turbo Rear Facing Camera Replacement: passo 17, immagine 1 di 3 Motorola Droid Turbo Rear Facing Camera Replacement: passo 17, immagine 2 di 3 Motorola Droid Turbo Rear Facing Camera Replacement: passo 17, immagine 3 di 3
    • Remove the rear-facing camera.
Conclusione
Altre 3 persone hanno completato questa guida.
Geoff Wacker
Membro da: 09/30/13
89.964 Reputazione
89 Guide realizzate
2 Commenti
Nice tut. However, I couldn't remove the 2 screws on the side of the USB connector. They seem to be rotating loosely with a trembling sound. Any ideas how to remove it?.
vdamiani - Replica
They’re not turning in the second section. The screw is just stuck in the black piece. Try using very pointed tweezers to help remove the screws. Put the points just underneath the screw head and hold it up as you unscrew it.
Rongwey - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 11
Tutti i Tempi: 2,048
