Salta al contenuto principale
Motorola Droid Rear Case Replacement
Cosa ti serve
  1. Motorola Droid Rear Case Replacement, Battery: passo 1, immagine 1 di 3 Motorola Droid Rear Case Replacement, Battery: passo 1, immagine 2 di 3 Motorola Droid Rear Case Replacement, Battery: passo 1, immagine 3 di 3
    • Slide the battery cover downwards while applying pressure to the center of the battery cover with your thumb.
    • Lift and remove the battery cover out from the phone.
  2. Motorola Droid Rear Case Replacement: passo 2, immagine 1 di 1
    • Grasp the upper left corner of the battery and lift it out of its housing.
  3. Motorola Droid Rear Case Replacement, Rear Case: passo 3, immagine 1 di 1
    • Use a spudger to lift and remove the black plastic screw cover at the top of the phone near the camera.
    • The cover is attached by adhesive, so some force may be required.
  4. Motorola Droid Rear Case Replacement: passo 4, immagine 1 di 2 Motorola Droid Rear Case Replacement: passo 4, immagine 2 di 2
    • Using the tip of a spudger, peel up one corner of the gold ribbon beneath the battery compartment.
    • Peel the ribbon up off the phone.
  5. Motorola Droid Rear Case Replacement: passo 5, immagine 1 di 2 Motorola Droid Rear Case Replacement: passo 5, immagine 2 di 2
    • Carefully peel the device information label that covers the motherboard EMI shields.
    • This label contains important information specific to the phone. Remove it with care and keep it in a safe place.
  6. Motorola Droid Rear Case Replacement: passo 6, immagine 1 di 1
    • Insert the flat end of a spudger and pry the plastic camera cover up off the phone.
    • The thin plastic cover is attached to the phone with an adhesive. Work slowly and carefully.
  7. Motorola Droid Rear Case Replacement: passo 7, immagine 1 di 1
    • Remove the seven 5.5 mm T5 Torx screws securing the rear case to the inner case.
  8. Motorola Droid Rear Case Replacement: passo 8, immagine 1 di 1
    • Insert the flat end of a spudger and pry downwards to release the plastic tab holding the rear case to the motherboard screw.
  9. Motorola Droid Rear Case Replacement: passo 9, immagine 1 di 1
    • Gently insert a spudger between the rear case and front case at the top of the phone, near the audio jack.
    • Carefully pry the top edge of the rear case up from the rest of the phone.
  10. Motorola Droid Rear Case Replacement: passo 10, immagine 1 di 2 Motorola Droid Rear Case Replacement: passo 10, immagine 2 di 2
    • With the spudger still inserted between the rear case and front case, slide the spudger along the right edge of the device, moving toward the bottom, prying as you go.
    • Continue prying along the bottom edge of the device from right to left, freeing it from the front panel.
  11. Motorola Droid Rear Case Replacement: passo 11, immagine 1 di 2 Motorola Droid Rear Case Replacement: passo 11, immagine 2 di 2
    • Continue prying the rear case from the front case along the left side, moving from bottom to top.
    • Lift the rear case up out of the phone.
Conclusione
Altre 6 persone hanno completato questa guida.
Brett Hartt
Membro da: 04/12/10
127.941 Reputazione
143 Guide realizzate
iFixit Membro di iFixit
Staff
136 Membri
17.298 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 15
Tutti i Tempi: 40,720
