Introduzione
Follow this guide to replace your Droid 2's broken or malfunctioning motherboard.
Parti
Nessuna parte richiesta.
Slide the battery cover toward the bottom edge of the phone. Remove the battery cover from the rear of the phone. Remove the battery cover from the rear of the phone.
  • Slide the battery cover toward the bottom edge of the phone.
  • Remove the battery cover from the rear of the phone.
Aggiungi Commento
Lift the battery out of the Droid 2 from the edge closest to the bottom of the phone. Remove the battery from the Droid 2.
  • Lift the battery out of the Droid 2 from the edge closest to the bottom of the phone.
  • Remove the battery from the Droid 2.
Aggiungi Commento
Using the tip of a spudger, peel up one corner of the silver ribbon below the battery compartment. Peel the ribbon off the phone.
  • Using the tip of a spudger, peel up one corner of the silver ribbon below the battery compartment.
  • Peel the ribbon off the phone.
Aggiungi Commento
Insert the flat end of a spudger and pry the plastic camera cover up off the phone.
  • Insert the flat end of a spudger and pry the plastic camera cover up off the phone.
  • The thin plastic cover is attached to the phone with an adhesive. Work slowly and carefully.
Aggiungi Commento
Use the tip of a spudger to remove the camera bezel stuck to the rear case.
  • Use the tip of a spudger to remove the camera bezel stuck to the rear case.
Aggiungi Commento
Remove the seven 5.5 mm T5 Torx screws securing the rear case to the inner case.
  • Remove the seven 5.5 mm T5 Torx screws securing the rear case to the inner case.
Aggiungi Commento
Insert the flat end of a spudger and pry downwards to release the plastic tab holding the rear case to the motherboard screw.
  • Insert the flat end of a spudger and pry downwards to release the plastic tab holding the rear case to the motherboard screw.
Aggiungi Commento
Gently insert a spudger between the rear case and front case at the top of the phone, near the audio jack.
  • Gently insert a spudger between the rear case and front case at the top of the phone, near the audio jack.
  • Carefully pry the top edge of the rear case up from the rest of the phone.
Aggiungi Commento
With the spudger still inserted between the rear case and front case, slide the spudger along the right edge of the device, moving toward the bottom, prying as you go. Continue prying along the bottom edge of the device from right to left, freeing it from the front panel.
  • With the spudger still inserted between the rear case and front case, slide the spudger along the right edge of the device, moving toward the bottom, prying as you go.
  • Continue prying along the bottom edge of the device from right to left, freeing it from the front panel.
Aggiungi Commento
Continue prying the rear case from the front case along the left side, moving from bottom to top. Lift the rear case up out of the phone.
  • Continue prying the rear case from the front case along the left side, moving from bottom to top.
  • Lift the rear case up out of the phone.
  • At this point, the button covers on the side of the phone are free and may fall out if you tip the phone upside down.
Aggiungi Commento
Carefully lift the speaker/antenna assembly up and out of the phone.
  • Carefully lift the speaker/antenna assembly up and out of the phone.
  • If you are re-assembling your phone, insert any power, camera, or volume buttons that may have fallen out at this point.
Aggiungi Commento
Use a spudger to pry the antenna cable connectors from their respective sockets on the motherboard and the speaker/antenna board. De-route the antenna cable by pulling it out of the metal clips along the side of the front case. De-route the antenna cable by pulling it out of the metal clips along the side of the front case.
  • Use a spudger to pry the antenna cable connectors from their respective sockets on the motherboard and the speaker/antenna board.
  • De-route the antenna cable by pulling it out of the metal clips along the side of the front case.
Aggiungi Commento
Peel the black rubber sheet covering the side button and display ribbon connectors on the motherboard.
  • Peel the black rubber sheet covering the side button and display ribbon connectors on the motherboard.
Aggiungi Commento
Disconnect the power button/volume button connector from its socket on the motherboard using the flat end of a spudger.
  • Disconnect the power button/volume button connector from its socket on the motherboard using the flat end of a spudger.
Aggiungi Commento
Disconnect the  display ribbon connector from its socket on the motherboard using the flat end of a spudger.
  • Disconnect the display ribbon connector from its socket on the motherboard using the flat end of a spudger.
Aggiungi Commento
Use the flat end of a spudger to remove the small black plastic piece stuck to the battery connector.
  • Use the flat end of a spudger to remove the small black plastic piece stuck to the battery connector.
Aggiungi Commento
Remove three 3.8 mm T5 Torx screws securing the motherboard to the front case.
  • Remove three 3.8 mm T5 Torx screws securing the motherboard to the front case.
  • Don't attempt to remove the motherboard yet, it is still attached by the keypad ribbon connector.
Aggiungi Commento
Carefully lift the motherboard from the front case and lay it next to the Droid 2, minding the keypad connector that is still attached.
  • Carefully lift the motherboard from the front case and lay it next to the Droid 2, minding the keypad connector that is still attached.
  • Disconnect the keypad connector by prying it straight up off its socket on the motherboard.
  • Remove the motherboard from the Droid 2.
Aggiungi Commento
Conclusione
Altre 6 persone hanno completato questa guida.
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 4
Tutti i Tempi: 9,577
