Introduzione
Use this guide to replace your Droid 2's LCD.
Slide the battery cover toward the bottom edge of the phone. Remove the battery cover from the rear of the phone. Remove the battery cover from the rear of the phone.
  • Slide the battery cover toward the bottom edge of the phone.
  • Remove the battery cover from the rear of the phone.
Aggiungi Commento
Lift the battery out of the Droid 2 from the edge closest to the bottom of the phone. Remove the battery from the Droid 2.
  • Lift the battery out of the Droid 2 from the edge closest to the bottom of the phone.
  • Remove the battery from the Droid 2.
Aggiungi Commento
Using the tip of a spudger, peel up one corner of the silver ribbon below the battery compartment. Peel the ribbon off the phone.
  • Using the tip of a spudger, peel up one corner of the silver ribbon below the battery compartment.
  • Peel the ribbon off the phone.
Aggiungi Commento
Insert the flat end of a spudger and pry the plastic camera cover up off the phone.
  • Insert the flat end of a spudger and pry the plastic camera cover up off the phone.
  • The thin plastic cover is attached to the phone with an adhesive. Work slowly and carefully.
Aggiungi Commento
Use the tip of a spudger to remove the camera bezel stuck to the rear case.
  • Use the tip of a spudger to remove the camera bezel stuck to the rear case.
Aggiungi Commento
Remove the seven 5.5 mm T5 Torx screws securing the rear case to the inner case.
  • Remove the seven 5.5 mm T5 Torx screws securing the rear case to the inner case.
Aggiungi Commento
Insert the flat end of a spudger and pry downwards to release the plastic tab holding the rear case to the motherboard screw.
  • Insert the flat end of a spudger and pry downwards to release the plastic tab holding the rear case to the motherboard screw.
Aggiungi Commento
Gently insert a spudger between the rear case and front case at the top of the phone, near the audio jack.
  • Gently insert a spudger between the rear case and front case at the top of the phone, near the audio jack.
  • Carefully pry the top edge of the rear case up from the rest of the phone.
Aggiungi Commento
With the spudger still inserted between the rear case and front case, slide the spudger along the right edge of the device, moving toward the bottom, prying as you go. Continue prying along the bottom edge of the device from right to left, freeing it from the front panel.
  • With the spudger still inserted between the rear case and front case, slide the spudger along the right edge of the device, moving toward the bottom, prying as you go.
  • Continue prying along the bottom edge of the device from right to left, freeing it from the front panel.
Aggiungi Commento
Continue prying the rear case from the front case along the left side, moving from bottom to top. Lift the rear case up out of the phone.
  • Continue prying the rear case from the front case along the left side, moving from bottom to top.
  • Lift the rear case up out of the phone.
  • At this point, the button covers on the side of the phone are free and may fall out if you tip the phone upside down.
Aggiungi Commento
Carefully lift the speaker/antenna assembly up and out of the phone.
  • Carefully lift the speaker/antenna assembly up and out of the phone.
  • If you are re-assembling your phone, insert any power, camera, or volume buttons that may have fallen out at this point.
Aggiungi Commento
Use a spudger to pry the antenna cable connectors from their respective sockets on the motherboard and the speaker/antenna board. De-route the antenna cable by pulling it out of the metal clips along the side of the front case. De-route the antenna cable by pulling it out of the metal clips along the side of the front case.
  • Use a spudger to pry the antenna cable connectors from their respective sockets on the motherboard and the speaker/antenna board.
  • De-route the antenna cable by pulling it out of the metal clips along the side of the front case.
Aggiungi Commento
Peel the black rubber sheet covering the side button and display ribbon connectors on the motherboard.
  • Peel the black rubber sheet covering the side button and display ribbon connectors on the motherboard.
Aggiungi Commento
Disconnect the power button/volume button connector from its socket on the motherboard using the flat end of a spudger.
  • Disconnect the power button/volume button connector from its socket on the motherboard using the flat end of a spudger.
Aggiungi Commento
Disconnect the  display ribbon connector from its socket on the motherboard using the flat end of a spudger.
  • Disconnect the display ribbon connector from its socket on the motherboard using the flat end of a spudger.
Aggiungi Commento
Use the flat end of a spudger to remove the small black plastic piece stuck to the battery connector.
  • Use the flat end of a spudger to remove the small black plastic piece stuck to the battery connector.
Aggiungi Commento
Remove three 3.8 mm T5 Torx screws securing the motherboard to the front case.
  • Remove three 3.8 mm T5 Torx screws securing the motherboard to the front case.
  • Don't attempt to remove the motherboard yet, it is still attached by the keypad ribbon connector.
Aggiungi Commento
Carefully lift the motherboard from the front case and lay it next to the Droid 2, minding the keypad connector that is still attached.
  • Carefully lift the motherboard from the front case and lay it next to the Droid 2, minding the keypad connector that is still attached.
  • Disconnect the keypad connector by prying it straight up off its socket on the motherboard.
  • Remove the motherboard from the Droid 2.
Aggiungi Commento
Disconnect the camera button/vibrator connector by prying it straight up off its socket on the speaker board with a spudger.
  • Disconnect the camera button/vibrator connector by prying it straight up off its socket on the speaker board with a spudger.
Aggiungi Commento
Remove the large sticker stuck to the inner face of the battery compartment.
  • Remove the large sticker stuck to the inner face of the battery compartment.
Aggiungi Commento
Slide the phone open. Lift up the edge of the black plastic rim that includes the speaker board from the side closest to the keypad.
  • Slide the phone open.
  • Lift up the edge of the black plastic rim that includes the speaker board from the side closest to the keypad.
  • Continue lifting the side of the rim until it is almost vertical, and wiggle it free from the back of the LCD assembly.
Aggiungi Commento
Remove the EMI shield by releasing the clips shown with the tip of a spudger.
  • Remove the EMI shield by releasing the clips shown with the tip of a spudger.
Aggiungi Commento
Remove the five 2.5 mm T3 Torx screws along the outer edge of the slider panel.
  • Remove the five 2.5 mm T3 Torx screws along the outer edge of the slider panel.
Aggiungi Commento
Slide the phone until a sixth screw is visible, as shown.
  • Slide the phone until a sixth screw is visible, as shown.
  • Remove the newly revealed 2.5 mm T3 Torx screw.
Aggiungi Commento
Continue sliding the phone in the same direction, past its "closed" position, until four more screws are revealed.
  • Continue sliding the phone in the same direction, past its "closed" position, until four more screws are revealed.
  • Remove the four 2.5 mm T3 Torx screws along the outer edge of the slider.
Aggiungi Commento
Return the phone to its normal "closed" position.
  • Return the phone to its normal "closed" position.
  • Peel the display ribbon up from the keypad's metal backing.
  • The ribbon cannot be completely removed yet, because it is attached to the back of the LCD.
  • At this point take extra caution as to not tear the ribbon cable.
Aggiungi Commento
Insert a spudger between the back and front case of the display assembly, and peel the two ribbon cables off the two adhesive pads along the back case of the display assembly. The location of the pads on the back case is shown.  The top left corner of the case is the corner of the phone shown in the first picture.
  • Insert a spudger between the back and front case of the display assembly, and peel the two ribbon cables off the two adhesive pads along the back case of the display assembly.
  • The location of the pads on the back case is shown. The top left corner of the case is the corner of the phone shown in the first picture.
Aggiungi Commento
Use the flat end of a spudger to lift the board that contains the ambient light sensor and display data cable connector out of the screen housing.
  • Use the flat end of a spudger to lift the board that contains the ambient light sensor and display data cable connector out of the screen housing.
Aggiungi Commento
Use the tip of a spudger to lift the speaker out of the screen housing. Use the tip of a spudger to lift the speaker out of the screen housing.
  • Use the tip of a spudger to lift the speaker out of the screen housing.
Aggiungi Commento
Peel off the black tape to reveal the front panel connector.
  • Peel off the black tape to reveal the front panel connector.
Aggiungi Commento
Remove the front panel ribbon cable from the ZIF connector on the board that is attached to the display ribbon.
  • Remove the front panel ribbon cable from the ZIF connector on the board that is attached to the display ribbon.
Aggiungi Commento
Flip the phone over and remove the front panel.
  • Flip the phone over and remove the front panel.
Aggiungi Commento
Slide the phone open. While feeding the display ribbon cable through the slot in the metal keypad backing, slowly continue to slide the phone open past its normal allowed point.
  • While feeding the display ribbon cable through the slot in the metal keypad backing, slowly continue to slide the phone open past its normal allowed point.
  • Continue feeding the display ribbon cable through and sliding the phone until the LCD assembly is separated from the keypad.
Aggiungi Commento
Lift the back cover off the display assembly, feeding the ribbon cable through the slit as you go.
  • Lift the back cover off the display assembly, feeding the ribbon cable through the slit as you go.
Aggiungi Commento
Peel away the black tape to reveal the display data cable connector.
  • Peel away the black tape to reveal the display data cable connector.
Aggiungi Commento
Use an iPod opening tool or fingernail to flip up the black lever on the ZIF connector. Pull the orange display data cable from the ZIF connector.
  • Use an iPod opening tool or fingernail to flip up the black lever on the ZIF connector.
  • Pull the orange display data cable from the ZIF connector.
Aggiungi Commento
Peel the display ribbon cable from the back of the LCD. The ribbon cable is attached with adhesive, so work slowly to avoid damaging it. Remove the display ribbon from the back of the LCD.
  • Peel the display ribbon cable from the back of the LCD. The ribbon cable is attached with adhesive, so work slowly to avoid damaging it.
  • Remove the display ribbon from the back of the LCD.
Aggiungi Commento
Conclusione
Altre 9 persone hanno completato questa guida.
the torx size on the A955 and the A956 that i own is T-2 and T-5 NOT T-3
mot nyt - Replica
Thank you very much for this tutorial. It saved me from buying a new phone! It was scary once the phone was completely disected to think that it had to somehow go back together, but I just followed the steps in reverse. I used t4 for the larger screws as t5 did not seem to fit, but it worked out great. Thanks again.
ibbman1 - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 10
Tutti i Tempi: 23,111
