Parti
Nessuna parte richiesta.
Wedge the plastic opening tool in between the back cover and the body of the phone in the opening denoted by the arrow.
  • Wedge the plastic opening tool in between the back cover and the body of the phone in the opening denoted by the arrow.
Aggiungi Commento
Once wedged in the opening, slide the opening tool sideways around the sides of the phone. Remove the back cover and set it aside.
  • Once wedged in the opening, slide the opening tool sideways around the sides of the phone. Remove the back cover and set it aside.
Aggiungi Commento
Insert the opening tool between the battery and the battery holder and wedge the battery out.
  • Insert the opening tool between the battery and the battery holder and wedge the battery out.
Aggiungi Commento
Open the plastic cover with your finger, exposing the SD card.
  • Open the plastic cover with your finger, exposing the SD card.
  • Use the opening tool to grab the edge of the SD card and pull it straight out.
Aggiungi Commento
Conclusione
Altre 2 persone hanno completato questa guida.
Dorian Capps
Membro da: 19/04/2013
64 Reputazione
2 Guide realizzate
Cal Poly, Team 2-22, Maness Spring 2013 Membro di Cal Poly, Team 2-22, Maness Spring 2013
CPSU-MANESS-S13S2G22
3 Membri
4 Guide realizzate
I have replaced the SD card --32 GB---with smaller GB card-- and still my XT phone does not allow movement of APP to this card or saving photo files.
Any other suggestions to get phone to recognize the new card. Cant drag an APP (calculator, eg) to that memory card.
Must I format or seat the card ? or get a different brand ScanDisk 32?
Memorex 8 with Settings reads 7.2 GB total space on this smaller new card.
Gardner
Gardner Neely - Replica
thanks for any guidance on memory card problems Mounting/activating so that I can add files or APPS to that SD card on my Motorola Defy XT 2012 mobile phone.
Gardner Neely -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 2,125
