Introduzione
Use this guide to replace the rear case.
Parti
Nessuna parte richiesta.
Using the screwdriver and the T-5 bit, unscrew the seven 5 mm screws around the outside of the phone.
  • Using the screwdriver and the T-5 bit, unscrew the seven 5 mm screws around the outside of the phone.
Aggiungi Commento
Remove the back cover of the phone by sliding the bottom black button to the unlock position and lifting it up. Remove the back cover of the phone by sliding the bottom black button to the unlock position and lifting it up.
  • Remove the back cover of the phone by sliding the bottom black button to the unlock position and lifting it up.
Aggiungi Commento
Conclusione
Morgan Roark
Membro da: 08/10/2014
327 Reputazione
3 Guide realizzate
USF Tampa, Team 14-2, Leahy Fall 2014 Membro di USF Tampa, Team 14-2, Leahy Fall 2014
USFT-LEAHY-F14S14G2
4 Membri
6 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 174
