Introduzione
This guide will go through the steps of replacing the speaker for the Motorola MB525 starting from the tear down of the phone to replacement of the speaker itself.
Using the screwdriver and the T-5 bit, unscrew the seven 5 mm screws around the outside of the phone.
  • Using the screwdriver and the T-5 bit, unscrew the seven 5 mm screws around the outside of the phone.
Aggiungi Commento
Remove the back cover of the phone by sliding the bottom black button to the unlock position and lifting it up. Remove the back cover of the phone by sliding the bottom black button to the unlock position and lifting it up.
  • Remove the back cover of the phone by sliding the bottom black button to the unlock position and lifting it up.
Aggiungi Commento
Use a plastic opening tool to pry the battery out of the phone.
  • Use a plastic opening tool to pry the battery out of the phone.
Aggiungi Commento
Unscrew the two silver screws located at the top of the back of the phone.
  • Unscrew the two silver screws located at the top of the back of the phone.
Aggiungi Commento
Use a plastic opening tool to gently pry the midframe from the rest of the phone.
  • Use a plastic opening tool to gently pry the midframe from the rest of the phone.
Aggiungi Commento
Use metal spudger to pry off the middle yellow flap carefully. Use metal spudger to pry off the middle yellow flap carefully.
  • Use metal spudger to pry off the middle yellow flap carefully.
Aggiungi Commento
Use tweezers again to pry off the second yellow flap carefully. Use tweezers again to pry off the second yellow flap carefully. Use tweezers again to pry off the second yellow flap carefully.
  • Use tweezers again to pry off the second yellow flap carefully.
Aggiungi Commento
The motherboard is the whole green board. Pry it off carefully with tweezers from the sides and place it aside.
  • The motherboard is the whole green board. Pry it off carefully with tweezers from the sides and place it aside.
Aggiungi Commento
Once the motherboard is removed, use either the metal tweezers or the metal spudger to remove the speaker by prying it as shown. The speaker is glued to its position, thus you will have to glue the new one back on.
  • Once the motherboard is removed, use either the metal tweezers or the metal spudger to remove the speaker by prying it as shown.
    • The speaker is glued to its position, thus you will have to glue the new one back on.
    • The speaker must be pried off carefully. It is very delicate.
Aggiungi Commento
Conclusione
Andres
Membro da: 08/10/2014
101 Reputazione
1 Guida realizzata
USF Tampa, Team 14-2, Leahy Fall 2014 Membro di USF Tampa, Team 14-2, Leahy Fall 2014
USFT-LEAHY-F14S14G2
4 Membri
6 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 458
