Salta al contenuto principale
Motorola Defy Display Assembly Replacement
Cosa ti serve
  1. Motorola Defy Display Assembly Replacement, Display Assembly: passo 1, immagine 1 di 2 Motorola Defy Display Assembly Replacement, Display Assembly: passo 1, immagine 2 di 2
    • Remove the battery cover and the battery itself.
  2. Motorola Defy Display Assembly Replacement: passo 2, immagine 1 di 2 Motorola Defy Display Assembly Replacement: passo 2, immagine 2 di 2
    • Using a Torx T5 screwdriver, remove both screws near the camera.
  3. Motorola Defy Display Assembly Replacement: passo 3, immagine 1 di 1
    • Using the Torx T5 screwdriver, remove all 7 screws around the mobile: 3 on each side + 1 on the botton.
  4. Motorola Defy Display Assembly Replacement: passo 4, immagine 1 di 3 Motorola Defy Display Assembly Replacement: passo 4, immagine 2 di 3 Motorola Defy Display Assembly Replacement: passo 4, immagine 3 di 3
    • Using a plastic opener tool, open the device removing the back cover.
    • Remove the power button and volume button.
  5. Motorola Defy Display Assembly Replacement: passo 5, immagine 1 di 3 Motorola Defy Display Assembly Replacement: passo 5, immagine 2 di 3 Motorola Defy Display Assembly Replacement: passo 5, immagine 3 di 3
    • After opening the device, carefully, using the plastic opening tool, peel off the lcd and digitalizer conectors from the mainboard.
  6. Motorola Defy Display Assembly Replacement: passo 6, immagine 1 di 1
    • Remove the two yellow rubber protectors near the screws. The rectangular yellow rubber protector might fall off too so put it aside.
  7. Motorola Defy Display Assembly Replacement: passo 7, immagine 1 di 1
    • Separate the Frame + Digitizer, the LCD and the mainboard.
  8. Motorola Defy Display Assembly Replacement: passo 8, immagine 1 di 3 Motorola Defy Display Assembly Replacement: passo 8, immagine 2 di 3 Motorola Defy Display Assembly Replacement: passo 8, immagine 3 di 3
    • Now, using a plastic opening tool, carefully insert it between the frame and the glass and force it slowly to remove the adhesive. You may also heat it to help.
    • Now, Remove the rest of adhesive from the frame to better apply the new digitizer on it.
    • Follow this backwards to reassemble the mobile.
Conclusione
Altre 11 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 5
Tutti i Tempi: 5,688
