Introduzione
This guide explains how to replace a damaged or broken motherboard on the Motorola Cliq. You will need to be ready to handle many small parts, including 4.0 mm screws and multiple small panels.
Turning over your phone, place two fingers on the back cover and apply pressure away from the camera to slide the back cover off. Turning over your phone, place two fingers on the back cover and apply pressure away from the camera to slide the back cover off.
  • Turning over your phone, place two fingers on the back cover and apply pressure away from the camera to slide the back cover off.
Aggiungi Commento
Pinch the battery pull tab located below the camera, pull it upwards, and remove the battery. The pull tab may be tucked under the battery.
  • Pinch the battery pull tab located below the camera, pull it upwards, and remove the battery.
    • The pull tab may be tucked under the battery.
Aggiungi Commento
Wedge a plastic opening tool behind the panel covering the camera, pry it up, and remove it using your fingers. The panel is held down by adhesive and may require you to wedge and pry the right side of the panel before it can be easily removed. The panel is held down by adhesive and may require you to wedge and pry the right side of the panel before it can be easily removed.
  • Wedge a plastic opening tool behind the panel covering the camera, pry it up, and remove it using your fingers.
    • The panel is held down by adhesive and may require you to wedge and pry the right side of the panel before it can be easily removed.
Aggiungi Commento
Remove the six 4.0 mm T4 Torx screws which line the edge of the back of the phone.
  • Remove the six 4.0 mm T4 Torx screws which line the edge of the back of the phone.
Aggiungi Commento
Turn the phone over and slide out the keyboard. Wedge a plastic opening tool where the keyboard meets the back casing of the phone next to the headphone jack. Carefully pry open the back casing along the keyboard's edge until at least two corners of the back casing are separated from the keyboard.
  • Turn the phone over and slide out the keyboard.
  • Wedge a plastic opening tool where the keyboard meets the back casing of the phone next to the headphone jack.
  • Carefully pry open the back casing along the keyboard's edge until at least two corners of the back casing are separated from the keyboard.
    • Do not fully separate the rear panel from the phone. A cable is connecting the two parts together.
Aggiungi Commento
Carefully separate the back casing from the rest of the phone.
  • Carefully separate the back casing from the rest of the phone.
Aggiungi Commento
Gently pry ZIF connector upwards using the flat end of a spudger tool. The ZIF connector is glued down. Be gentle! Ripping it off or breaking it will make your phone inoperable.
  • Gently pry ZIF connector upwards using the flat end of a spudger tool.
    • The ZIF connector is glued down. Be gentle! Ripping it off or breaking it will make your phone inoperable.
    • You may need adhesive to keep your power cable in place when reassembling your phone.
Aggiungi Commento
Press your thumb against the orange power cable and pull it down slowly to disconnect the power cable from the bottom of the keyboard. The rear casing and the rest of the phone should now be completely separated. The rear casing and the rest of the phone should now be completely separated.
  • Press your thumb against the orange power cable and pull it down slowly to disconnect the power cable from the bottom of the keyboard.
  • The rear casing and the rest of the phone should now be completely separated.
Aggiungi Commento
Wedge the plastic opening tool underneath the black display connector and pry it off its socket on the motherboard. Wedge the plastic opening tool underneath the black display connector and pry it off its socket on the motherboard.
  • Wedge the plastic opening tool underneath the black display connector and pry it off its socket on the motherboard.
Aggiungi Commento
Pry the orange keyboard connector from its socket on the motherboard using the edge of the plastic opening tool. Pry the orange keyboard connector from its socket on the motherboard using the edge of the plastic opening tool.
  • Pry the orange keyboard connector from its socket on the motherboard using the edge of the plastic opening tool.
Aggiungi Commento
Carefully grab the sides of the motherboard with your fingers and remove it from the phone. Carefully grab the sides of the motherboard with your fingers and remove it from the phone. Carefully grab the sides of the motherboard with your fingers and remove it from the phone.
  • Carefully grab the sides of the motherboard with your fingers and remove it from the phone.
Aggiungi Commento
Conclusione
Altre 3 persone hanno completato questa guida.
Tony Tran
Membro da: 14/04/2013
64 Reputazione
8 Guide realizzate
Cal Poly, Team 10-42, Amido Spring 2013 Membro di Cal Poly, Team 10-42, Amido Spring 2013
CPSU-AMIDO-S13S10G42
4 Membri
8 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 438
