Introduzione
Use this guide to replace the keypad guard on the front of the phone.
Cosa ti serve
Remove the battery by sliding it down the rails to which it is connected.
Put the back case down on a table in front of you with the bottom of the phone close to you.
Put the key guard's tabs into the corresponding tabs on the bottom of the rear casing.
While the key guard's tabs are in the rear casing, put the rear casing's tabs into the bottom of the front casing.
Locate the holes that connect the keypad guard to the rear casing.
Find a thin and sturdy screwdriver.
Insert the screwdriver into the holes in the plastic rod connecting the key pad guard to the rear casing.
Use the screwdriver to push the rods away from each other until they click into a locked position.
