Introduzione
Battery replacement is fairly straightforward and involves little disassembly.
Remove the old battery by sliding it down the rails that it connects to.
  • Remove the old battery by sliding it down the rails that it connects to.
Aggiungi Commento
With the back of the phone exposed, align the top of the new battery with the bottom end of the phone rails.
  • With the back of the phone exposed, align the top of the new battery with the bottom end of the phone rails.
Aggiungi Commento
Slide the battery upward along the rails.
  • Slide the battery upward along the rails.
    • Do not force the battery; it should move along the rails with little resistance.
    • Be careful not to pinch fingers, catch hair, etc. in between the phone and battery while moving.
Aggiungi Commento
Continue sliding until the battery snaps into place. It should be secure and immobile when completely installed.
  • Continue sliding until the battery snaps into place. It should be secure and immobile when completely installed.
Aggiungi Commento
Conclusione
To remove the battery, follow these steps in reverse order. To unlock the battery, hold down the key before sliding.
Marianne
Membro da: 19/04/2012
13 Reputazione
2 Guide realizzate
Cal Poly, Team 9-46, Regan Spring 2012 Membro di Cal Poly, Team 9-46, Regan Spring 2012
CPSU-REGAN-S12S9G46
5 Membri
8 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 1,098
