Introduzione
Use this guide to replace the motherboard in your Motorola C350.
Parti
Nessuna parte richiesta.
Use your finger to press the button and free the device rear case. You may have to force it a bit more to free its bottom if you open it for the first time.
  • Use your finger to press the button and free the device rear case.
  • You may have to force it a bit more to free its bottom if you open it for the first time.
Aggiungi Commento
slide the black button to free the battery so you can grab it with your other hand.
  • slide the black button to free the battery so you can grab it with your other hand.
Aggiungi Commento
You will see one plastic clip on each side of the device. Use your thumbs to push them apart and being able to separate the front case from the device other components. You will see one plastic clip on each side of the device. Use your thumbs to push them apart and being able to separate the front case from the device other components.
  • You will see one plastic clip on each side of the device. Use your thumbs to push them apart and being able to separate the front case from the device other components.
Aggiungi Commento
Remove the 4 T6 Torx screws Remove the 4 T6 Torx screws
  • Remove the 4 T6 Torx screws
Aggiungi Commento
Use a metal spudger to pell off the four metal clips and separate the motherboard and keyboard from the main plastic part. Use a metal spudger to pell off the four metal clips and separate the motherboard and keyboard from the main plastic part.
  • Use a metal spudger to pell off the four metal clips and separate the motherboard and keyboard from the main plastic part.
Aggiungi Commento
The last thing you need to doto access the Logic Board is to separate the Keyboard/Screen block just taking apart with your fingers.
  • The last thing you need to doto access the Logic Board is to separate the Keyboard/Screen block just taking apart with your fingers.
Aggiungi Commento
Conclusione
Vincent Monteil
Membro da: 06/07/2013
6.161 Reputazione
21 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 424
