Introduzione
Use this guide to replace the earpiece speaker in your Motorola C350.
Parti
Nessuna parte richiesta.
Use your finger to press the button and free the device rear case. You may have to force it a bit more to free its bottom if you open it for the first time.
  • Use your finger to press the button and free the device rear case.
  • You may have to force it a bit more to free its bottom if you open it for the first time.
Aggiungi Commento
slide the black button to free the battery so you can grab it with your other hand.
  • slide the black button to free the battery so you can grab it with your other hand.
Aggiungi Commento
You will see one plastic clip on each side of the device. Use your thumbs to push them apart and being able to separate the front case from the device other components. You will see one plastic clip on each side of the device. Use your thumbs to push them apart and being able to separate the front case from the device other components.
  • You will see one plastic clip on each side of the device. Use your thumbs to push them apart and being able to separate the front case from the device other components.
Aggiungi Commento
Remove the four T6 Torx Screws Remove the four T6 Torx Screws
  • Remove the four T6 Torx Screws
Aggiungi Commento
Use a metal spudger togently free the screen/ear speaker metal case.
  • Use a metal spudger togently free the screen/ear speaker metal case.
Aggiungi Commento
Slowly peel the ear speaker off the case.
  • Slowly peel the ear speaker off the case.
  • Be really careful about the small plastic pin which can be easily lost.
Aggiungi Commento
Conclusione
Vincent Monteil
Membro da: 06/07/2013
6.161 Reputazione
21 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 364
