Introduzione
This repair guide shows how to replace the antenna of the Motorola C290.
Strumenti
Nessun attrezzo richiesto.
Parti
Nessuna parte richiesta.
Position Motorola C290 so that the back of the phone is facing up. Apply pressure to the back cover while simultaneously sliding it downwards.
  • Position Motorola C290 so that the back of the phone is facing up.
  • Apply pressure to the back cover while simultaneously sliding it downwards.
  • Note: It may be easiest to apply pressure to the ridges at the top of the back cover.
Aggiungi Commento
Place your finger in the notch at the top of the battery. Gently lift and pull out battery.
  • Place your finger in the notch at the top of the battery.
  • Gently lift and pull out battery.
Aggiungi Commento
Unscrew antenna head from top of phone by twisting counterclockwise. Pull the antenna out through the top hole and set aside. Pull the antenna out through the top hole and set aside.
  • Unscrew antenna head from top of phone by twisting counterclockwise.
  • Pull the antenna out through the top hole and set aside.
Aggiungi Commento
Remove the plastic tube by lifting the bottom and pulling out towards yourself. Remove the plastic tube by lifting the bottom and pulling out towards yourself.
  • Remove the plastic tube by lifting the bottom and pulling out towards yourself.
Aggiungi Commento
Conclusione
Cal Poly, Team 24-28, Regan Spring 2010 Membro di Cal Poly, Team 24-28, Regan Spring 2010
CPSU-REGAN-S10S24G28
4 Membri
6 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 1,882
