Introduzione
This guide details the steps involved with replacing the keypad or faceplate on the Motorola C139
Parti
Nessuna parte richiesta.
Begin by flipping your phone over so that the back cover is facing up. Apply force to the back cover and simultaneously slide the cover down. Note: Applying pressure on the ridges will make it easier to remove the cover.
  • Begin by flipping your phone over so that the back cover is facing up.
  • Apply force to the back cover and simultaneously slide the cover down.
  • Note: Applying pressure on the ridges will make it easier to remove the cover.
Aggiungi Commento
Press the button labeled "PUSH" located at the bottom back of the phone. This will release the battery. Lift and remove the battery. Lift and remove the battery.
  • Press the button labeled "PUSH" located at the bottom back of the phone. This will release the battery.
  • Lift and remove the battery.
Aggiungi Commento
Use a Torx T-5 screwdriver to remove the screws on the back of the phone. The screws are 6.86 mm long and 1.61mm in diameter. The screws are 6.86 mm long and 1.61mm in diameter.
  • Use a Torx T-5 screwdriver to remove the screws on the back of the phone.
  • The screws are 6.86 mm long and 1.61mm in diameter.
Aggiungi Commento
Slide a pry tool underneath the adhesive rubber stip and peel it back away from the phone. Repeat for the other side Repeat for the other side
  • Slide a pry tool underneath the adhesive rubber stip and peel it back away from the phone.
  • Repeat for the other side
Aggiungi Commento
Insert the pry tool in the slit on the side of the phone and slide it down until you hear an audible click and the phone bottom loosens from the top. Use the pry tool to release the two hooks on each side and the two hooks at the top holding the case together. Release a total of six hooks from the sides and top to free the phone into two halves.
  • Insert the pry tool in the slit on the side of the phone and slide it down until you hear an audible click and the phone bottom loosens from the top.
    • Use the pry tool to release the two hooks on each side and the two hooks at the top holding the case together.
  • Release a total of six hooks from the sides and top to free the phone into two halves.
Aggiungi Commento
Using a Torx T-5 screwdriver remove the screws at the top of the phone. The screws are 6.86 mm long and 1.61mm in diameter. The screws are 6.86 mm long and 1.61mm in diameter.
  • Using a Torx T-5 screwdriver remove the screws at the top of the phone.
Aggiungi Commento
Use plastic pry tools to free the circuit board from the case There are two hooks (one on each side) holding the circuit board into the case. Then grip the circuit board and lift to remove the circuit board from the case
  • Use plastic pry tools to free the circuit board from the case
    • There are two hooks (one on each side) holding the circuit board into the case.
  • Then grip the circuit board and lift to remove the circuit board from the case
Aggiungi Commento
On the top half of the phone push downwards on the number keys to free the keypad from the top of the phone. On the top half of the phone push downwards on the number keys to free the keypad from the top of the phone.
  • On the top half of the phone push downwards on the number keys to free the keypad from the top of the phone.
Aggiungi Commento
Conclusione
Clemson, Team 2-2, Benson Spring 2012 Membro di Clemson, Team 2-2, Benson Spring 2012
CLEM-BENSON-S12S2G2
3 Membri
15 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 886
