Salta al contenuto principale
Motorola Atrix 4G Motherboard Replacement
Cosa ti serve
  1. Motorola Atrix 4G Motherboard Replacement, Battery: passo 1, immagine 1 di 1
    • Pry the rear cover from the back of the phone.
  2. Motorola Atrix 4G Motherboard Replacement: passo 2, immagine 1 di 2 Motorola Atrix 4G Motherboard Replacement: passo 2, immagine 2 di 2
    • Insert a spudger or plastic opening tool into the small notch at the base of the battery.
    • Lift the battery out of the phone.
  3. Motorola Atrix 4G Motherboard Replacement, Antenna: passo 3, immagine 1 di 3 Motorola Atrix 4G Motherboard Replacement, Antenna: passo 3, immagine 2 di 3 Motorola Atrix 4G Motherboard Replacement, Antenna: passo 3, immagine 3 di 3
    • Remove the four 5.0 mm T5 Torx screws from the corners of the phone.
    • Remove three 5.5 mm T5 Torx screws from the back of the phone.
    • Lift up the black rubber flap near the SD card slot.
    • Remove the single 5.5 mm T5 Torx screw beneath the flap.
    • Do not attempt to loosen the screws with too much force. These screws are small, and easily stripped.
  4. Motorola Atrix 4G Motherboard Replacement: passo 4, immagine 1 di 2 Motorola Atrix 4G Motherboard Replacement: passo 4, immagine 2 di 2
    • Remove the back case of the phone by gently lifting the tabs located on top of the phone near the lock button.
    • Use the case opener or spudger in these small areas because the plastic tabs can be easily broken.
    • Lift the tabs located on the bottom of the phone to continue removing the back cover.
  5. Motorola Atrix 4G Motherboard Replacement: passo 5, immagine 1 di 2 Motorola Atrix 4G Motherboard Replacement: passo 5, immagine 2 di 2
    • Slide an opening tool between the gap from the back of the case to the front.
    • After separating the sides, make sure there is a noticeable gap between the back case and the rest of the phone.
    • After detaching the tabs and sliding down the sides, there should be a noticeable gap between the front and back cases.
  6. Motorola Atrix 4G Motherboard Replacement: passo 6, immagine 1 di 1
    • Carefully separate the back case from the rest of the phone by lifting it away from the phone.
    • Do not completely remove the case from the rest of the phone. The antenna is connected to both cases.
  7. Motorola Atrix 4G Motherboard Replacement: passo 7, immagine 1 di 1
    • Disconnect the antenna from its housing on the motherboard by gently lifting beneath it.
  8. Motorola Atrix 4G Motherboard Replacement: passo 8, immagine 1 di 1
    • Ease the antenna from out of its guide along the side of the phone
    • Once the antenna is detached, remove the back case and the antenna from the phone
    • The antenna is soldered to the back case. Do not pull with too much force.
  9. Motorola Atrix 4G Motherboard Replacement, Motherboard: passo 9, immagine 1 di 2 Motorola Atrix 4G Motherboard Replacement, Motherboard: passo 9, immagine 2 di 2
    • To remove the motherboard, first dislodge the right side of the motherboard, where the external connections are located, from the rest of the phone.
    • This can be done by placing a spudger in between the two ports on the phone, between the black plastic and motherboard, and prying out.
    • The motherboard should be able to be easily lifted upwards after dislodging it.
    • If the white rubber piece moves, replace it where it came from upon reassembly.
  10. Motorola Atrix 4G Motherboard Replacement: passo 10, immagine 1 di 2 Motorola Atrix 4G Motherboard Replacement: passo 10, immagine 2 di 2
    • First, several connections must be disconnected to completely separate the motherboard from the rest of the phone.
    • The connection highlighted with a red box must be pulled down instead of out.
    • Using the spudger tool, separate the two connections on the motherboard highlighted with orange circles by pulling them out.
    • The black switch on top of this connection acts as a lock. Push it forwards to unlock the connection.
  11. Motorola Atrix 4G Motherboard Replacement: passo 11, immagine 1 di 1
    • After disconnecting the motherboard, there should be five distinct and separate parts of the phone: back cover, back case, front case, battery, and motherboard.
Conclusione
Altre 5 persone hanno completato questa guida.
Derek Walker
Membro da: 04/19/12
297 Reputazione
4 Guide realizzate
Cal Poly, Team 9-42, Regan Spring 2012 Membro di Cal Poly, Team 9-42, Regan Spring 2012
CPSU-REGAN-S12S9G42
6 Membri
15 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 6,424
