Introduzione
This process involves first removing the battery and outer case. After, the motherboard can be easily removed.
Parti
Nessuna parte richiesta.
Hold the phone and pull the back latch down towards the bottom. Remove the back panel by releasing the latch and lifting from the top.
  • Hold the phone and pull the back latch down towards the bottom.
  • Remove the back panel by releasing the latch and lifting from the top.
Aggiungi Commento
Remove the battery by pushing the bottom end towards the top, then lifting up. Remove the battery by pushing the bottom end towards the top, then lifting up. Remove the battery by pushing the bottom end towards the top, then lifting up.
  • Remove the battery by pushing the bottom end towards the top, then lifting up.
Aggiungi Commento
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
Once the battery is out, unscrew the six 7.0 mm screws with T-6 screwdriver. Once the screws are removed, simply lift the back panel off Once the screws are removed, simply lift the back panel off
  • Once the battery is out, unscrew the six 7.0 mm screws with T-6 screwdriver.
  • Once the screws are removed, simply lift the back panel off
Aggiungi Commento
Remove the motherboard by lifting it up and out. Remove the motherboard by lifting it up and out. Remove the motherboard by lifting it up and out.
  • Remove the motherboard by lifting it up and out.
Aggiungi Commento
Conclusione
Leonel Arjon
Membro da: 10/04/2012
11 Reputazione
2 Guide realizzate
Cal Poly, Team 6-21, Amido Spring 2012 Membro di Cal Poly, Team 6-21, Amido Spring 2012
CPSU-AMIDO-S12S6G21
4 Membri
14 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 567
