Introduzione
If you're having sound issues, your speakers may be broken. Follow these steps to replace them.
Parti
Nessuna parte richiesta.
Turn the device so the screen is facing down.
  • Turn the device so the screen is facing down.
Aggiungi Commento
Slide the battery lock switch next to the power slider to the unlocked position. Slide the battery lock switch next to the power slider to the unlocked position.
  • Slide the battery lock switch next to the power slider to the unlocked position.
Aggiungi Commento
Slide and hold the switch by the fan vent to the unlocked position. Firmly grasp the battery and pull away from tablet. When replacing the battery, place the end near the fan vent in first. Make sure to keep the other switch in the unlocked position while pushing the battery into place. When replacing the battery, place the end near the fan vent in first. Make sure to keep the other switch in the unlocked position while pushing the battery into place.
  • Slide and hold the switch by the fan vent to the unlocked position. Firmly grasp the battery and pull away from tablet.
  • When replacing the battery, place the end near the fan vent in first. Make sure to keep the other switch in the unlocked position while pushing the battery into place.
Aggiungi Commento
Unscrew hard drive panel using a Phillips head #1 screwdriver.
  • Unscrew hard drive panel using a Phillips head #1 screwdriver.
  • (Our device was not given to us with a hard drive or a hard drive panel)
Aggiungi Commento
Pull clear plastic tab to detach hard drive from tablet. Pull clear plastic tab to detach hard drive from tablet. Pull clear plastic tab to detach hard drive from tablet.
  • Pull clear plastic tab to detach hard drive from tablet.
Aggiungi Commento
To disconnect the three white ribbon cables on the side closest to the hard drive connector, pull the white plastic tabs. To disconnect the three white ribbon cables on the side closest to the hard drive connector, pull the white plastic tabs.
  • To disconnect the three white ribbon cables on the side closest to the hard drive connector, pull the white plastic tabs.
Aggiungi Commento
Pull the brown tabs to disconnect the white ribbon cable on the other side.
  • Pull the brown tabs to disconnect the white ribbon cable on the other side.
Aggiungi Commento
Caution: do not pull on the wires, instead pull from the plastic connectors. To disconnect the remaining ribbon cables, pull the plastic connectors away from their connections.
  • Caution: do not pull on the wires, instead pull from the plastic connectors.
  • To disconnect the remaining ribbon cables, pull the plastic connectors away from their connections.
Aggiungi Commento
With a Phillips #1 screwdriver, Unscrew the nine 10mm screws holding the case together.
  • With a Phillips #1 screwdriver, Unscrew the nine 10mm screws holding the case together.
Aggiungi Commento
Using a spudger, press in the five tabs on the side where the battery was.
  • Using a spudger, press in the five tabs on the side where the battery was.
  • This should separate the two halves of the device. Carefully set the side with the display off to the side.
Aggiungi Commento
Locate the Bluetooth board. Disconnect the ribbon cable by pulling on the plastic connector. Disconnect the ribbon cable by pulling on the plastic connector.
  • Locate the Bluetooth board.
  • Disconnect the ribbon cable by pulling on the plastic connector.
Aggiungi Commento
Unscrew the 4mm screw holding the board onto the tablet. Lift the board out of the tablet and carefully set it aside.
  • Unscrew the 4mm screw holding the board onto the tablet.
  • Lift the board out of the tablet and carefully set it aside.
Aggiungi Commento
Locate speaker connectors on tablet and unplug them by pulling on the plastic heads. Locate speaker connectors on tablet and unplug them by pulling on the plastic heads. Locate speaker connectors on tablet and unplug them by pulling on the plastic heads.
  • Locate speaker connectors on tablet and unplug them by pulling on the plastic heads.
Aggiungi Commento
To remove the speaker near the network port, unscrew the two black 4mm screws securing it to the tablet and pull away. To remove the speaker near the network port, unscrew the two black 4mm screws securing it to the tablet and pull away.
  • To remove the speaker near the network port, unscrew the two black 4mm screws securing it to the tablet and pull away.
Aggiungi Commento
To remove the speaker near the headphone jack, unscrew the one 4mm black screw securing it to the tablet. To remove the speaker near the headphone jack, unscrew the one 4mm black screw securing it to the tablet.
  • To remove the speaker near the headphone jack, unscrew the one 4mm black screw securing it to the tablet.
Aggiungi Commento
Unstick the white masking tape and the black electrical tape holding the black and red wire down. Pull out the wire and speaker.
  • Unstick the white masking tape and the black electrical tape holding the black and red wire down.
  • Pull out the wire and speaker.
Aggiungi Commento
Conclusione
David Troy
Membro da: 04/04/2012
44 Reputazione
3 Guide realizzate
Cal Poly, Team 15-14, Forte Spring 2012 Membro di Cal Poly, Team 15-14, Forte Spring 2012
CPSU-FORTE-S12S15G14
5 Membri
5 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 866
