Introduzione
If the buttons on the front of the device aren't responding, you may have a faulty button board. Follow the instructions below to replace your button board.
Parti
Nessuna parte richiesta.
Turn the device so the screen is facing down.
  • Turn the device so the screen is facing down.
Aggiungi Commento
Slide the battery lock switch next to the power slider to the unlocked position. Slide the battery lock switch next to the power slider to the unlocked position.
  • Slide the battery lock switch next to the power slider to the unlocked position.
Aggiungi Commento
Slide and hold the switch by the fan vent to the unlocked position. Firmly grasp the battery and pull away from tablet. When replacing the battery, place the end near the fan vent in first. Make sure to keep the other switch in the unlocked position while pushing the battery into place. When replacing the battery, place the end near the fan vent in first. Make sure to keep the other switch in the unlocked position while pushing the battery into place.
  • Slide and hold the switch by the fan vent to the unlocked position. Firmly grasp the battery and pull away from tablet.
  • When replacing the battery, place the end near the fan vent in first. Make sure to keep the other switch in the unlocked position while pushing the battery into place.
Aggiungi Commento
Unscrew hard drive panel using a Phillips head #1 screwdriver.
  • Unscrew hard drive panel using a Phillips head #1 screwdriver.
  • (Our device was not given to us with a hard drive or a hard drive panel)
Aggiungi Commento
Pull clear plastic tab to detach hard drive from tablet. Pull clear plastic tab to detach hard drive from tablet. Pull clear plastic tab to detach hard drive from tablet.
  • Pull clear plastic tab to detach hard drive from tablet.
Aggiungi Commento
To disconnect the three white ribbon cables on the side closest to the hard drive connector, pull the white plastic tabs. To disconnect the three white ribbon cables on the side closest to the hard drive connector, pull the white plastic tabs.
  • To disconnect the three white ribbon cables on the side closest to the hard drive connector, pull the white plastic tabs.
Aggiungi Commento
Pull the brown tabs to disconnect the white ribbon cable on the other side.
  • Pull the brown tabs to disconnect the white ribbon cable on the other side.
Aggiungi Commento
Caution: do not pull on the wires, instead pull from the plastic connectors. To disconnect the remaining ribbon cables, pull the plastic connectors away from their connections.
  • Caution: do not pull on the wires, instead pull from the plastic connectors.
  • To disconnect the remaining ribbon cables, pull the plastic connectors away from their connections.
Aggiungi Commento
With a Phillips #1 screwdriver, Unscrew the nine 10mm screws holding the case together.
  • With a Phillips #1 screwdriver, Unscrew the nine 10mm screws holding the case together.
Aggiungi Commento
Using a spudger, press in the five tabs on the side where the battery was. This should separate the two halves of the device. Carefully set the side with the motherboard off to the side.
  • Using a spudger, press in the five tabs on the side where the battery was.
  • This should separate the two halves of the device. Carefully set the side with the motherboard off to the side.
Aggiungi Commento
Unplug the three ribbon cables by pulling on the brown tabs and unplugging cable. Unplug the three ribbon cables by pulling on the brown tabs and unplugging cable.
  • Unplug the three ribbon cables by pulling on the brown tabs and unplugging cable.
Aggiungi Commento
With a Phillips #1 screwdriver, unscrew the three 4mm screws holding the display bracket on the back side of the front buttons. With a Phillips #1 screwdriver, unscrew the three 4mm screws holding the display bracket on the back side of the front buttons.
  • With a Phillips #1 screwdriver, unscrew the three 4mm screws holding the display bracket on the back side of the front buttons.
Aggiungi Commento
Remove the button board and replace. Remove the button board and replace.
  • Remove the button board and replace.
Aggiungi Commento
Conclusione
Fred Wilby
Membro da: 03/04/2012
67 Reputazione
1 Guida realizzata
Cal Poly, Team 15-14, Forte Spring 2012 Membro di Cal Poly, Team 15-14, Forte Spring 2012
CPSU-FORTE-S12S15G14
5 Membri
5 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 6
Tutti i Tempi: 1,589
