Introduzione
Replacing the battery is a very simple task which only requires a spare coin and replacement battery.
Flip the camera so that the bottom is facing you. Take a spare coin and unscrew the battery cover off.
  • Flip the camera so that the bottom is facing you.
  • Take a spare coin and unscrew the battery cover off.
Aggiungi Commento
Remove the batteries, making sure to note their proper alignment.
  • Remove the batteries, making sure to note their proper alignment.
Aggiungi Commento
Conclusione
Altre 2 persone hanno completato questa guida.
Nick
Membro da: 19/04/2011
411 Reputazione
4 Guide realizzate
Cal Poly, Team 8-7, Regan Spring 2011 Membro di Cal Poly, Team 8-7, Regan Spring 2011
CPSU-REGAN-S11S8G7
4 Membri
4 Guide realizzate
Hi there, i'm a bit stuck, in my 35mm SLR i was taking a shot and the batteries died, leaving the mirror stuck in the up position, i've changed the batteries and the release for the shutter won't click, i can't advance the film lever and so it's a sitting duck at the moment. They're brand new batteries but because the mirror is up i can't even see if the metering works. because i'm half way through a roll of film i don't want to open the back and ruin it so i'm wondering if there's any way to get the shutter to release again or to get the mirror back down, i don't mind loosing a few blank exposures but again i really wouldn't want to ruin the film. Many thanks and i hope you can get back to me,
Cameron
Cameron Tyson - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 8
Ultimi 7 Giorni: 36
Ultimi 30 Giorni: 167
Tutti i Tempi: 7,820
