Salta al contenuto principale
Midland X-tra Talk Radio LXT118 Circuit Board Replacement
Cosa ti serve
  1. Midland X-tra Talk Radio LXT118 Circuit Board Replacement, Midland X-tra Talk Radio LXT118: passo 1, immagine 1 di 1
    • Remove the old or broken circuit board from the front case by carefully separating it from the back.
    • Clip the red and black wires at the base of the motherboard to completely separate it from the radio case. You should have 2 separate pieces.
  2. Midland X-tra Talk Radio LXT118 Circuit Board Replacement, Circuit Board: passo 2, immagine 1 di 1
    • Reattach the speaker wires and antenna to the new circuit board using a soldering iron. Take caution when using the hot soldering tool!
Conclusione
Altre 2 persone hanno completato questa guida.
Cal Poly, Team 19-43, Regan Winter 2013 Membro di Cal Poly, Team 19-43, Regan Winter 2013
CPSU-REGAN-W13S19G43
3 Membri
9 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 16
Tutti i Tempi: 1,220
