Introduzione
This guide will display the step-by-step process of fixing and/or replacing a faulty antenna. Soldering may be involved, so be prepared!
Parti
Nessuna parte richiesta.
First, apply pressure with your thumb on the top of the battery cover.
  • First, apply pressure with your thumb on the top of the battery cover.
Aggiungi Commento
Next, pull down on the cover until it begins to slide.
  • Next, pull down on the cover until it begins to slide.
Aggiungi Commento
Finally, once the cover is completely off, pry up the old batteries with your finger or a strong, skinny tool (i.e. spudger).
  • Finally, once the cover is completely off, pry up the old batteries with your finger or a strong, skinny tool (i.e. spudger).
Aggiungi Commento
Unscrew the six 8.0 millimeter long, #0 screws on the backside of the case using the Phillips #0 screwdriver.
  • Unscrew the six 8.0 millimeter long, #0 screws on the backside of the case using the Phillips #0 screwdriver.
Aggiungi Commento
Detach back part of the case by gently lifting up.
  • Detach back part of the case by gently lifting up.
Aggiungi Commento
Carefully and slowly lift the motherboard away from the front case. The motherboard will be attached to the speaker, which is firmly glued onto the front case.
  • Carefully and slowly lift the motherboard away from the front case. The motherboard will be attached to the speaker, which is firmly glued onto the front case.
Aggiungi Commento
Check the connection of the antenna with your eyes and fingers.  The connection should be firm and smooth where it was soldered.
  • Check the connection of the antenna with your eyes and fingers. The connection should be firm and smooth where it was soldered.
  • Ensure that the spring of the antenna isn't crooked or damaged by rubbing your fingers along the length of the spring.
  • Desolder the connection of the antenna to the motherboard. Careful!, if used improperly, the soldering tool can damage the circuit board!
Aggiungi Commento
After obtaining a new or undamaged spring, solder it back onto the circuit board.  Again, this is a delacate process as the soldering tool will be hot!
  • After obtaining a new or undamaged spring, solder it back onto the circuit board. Again, this is a delacate process as the soldering tool will be hot!
Aggiungi Commento
Conclusione
Altre 5 persone hanno completato questa guida.
Andre Nguyen
Membro da: 18/01/2013
108 Reputazione
1 Guida realizzata
Cal Poly, Team 19-43, Regan Winter 2013 Membro di Cal Poly, Team 19-43, Regan Winter 2013
CPSU-REGAN-W13S19G43
3 Membri
9 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 15
Tutti i Tempi: 914
