Introduzione
This guide will show you how to replace the scanners stepper motor.
Parti
Nessuna parte richiesta.
Loosen the screws on the serial port by turning them counter clockwise by hand. After loosening the screws, pull the serial port out. After loosening the screws, pull the serial port out.
  • Loosen the screws on the serial port by turning them counter clockwise by hand.
  • After loosening the screws, pull the serial port out.
Aggiungi Commento
Lift lid to its vertical position. Pull lid straight up to remove it from the scanner. Pull lid straight up to remove it from the scanner.
  • Lift lid to its vertical position.
  • Pull lid straight up to remove it from the scanner.
Aggiungi Commento
Push the plastic opening tools into the crack between the top and the bottom of the chassis. Push the plastic opening tools into the crack between the top and the bottom of the chassis. Push the plastic opening tools into the crack between the top and the bottom of the chassis.
  • Push the plastic opening tools into the crack between the top and the bottom of the chassis.
Aggiungi Commento
After placing one plastic opening tool into the slit, slide other plastic opening tools along the slit to detach the top from the bottom of the chassis. Go all the way along the chassis until you can lift the upper lid. Go all the way along the chassis until you can lift the upper lid.
  • After placing one plastic opening tool into the slit, slide other plastic opening tools along the slit to detach the top from the bottom of the chassis.
  • Go all the way along the chassis until you can lift the upper lid.
Aggiungi Commento
Do not fully remove the lid until you remove the ribbon cable attached to the front of the upper lid. Do this by grabbing the upper lid from the sides and rotating it ninety degrees so it is perpendicular to the bottom lid. Grab the ribbon cable and gently pull it out of its slot with your fingers.
  • Do not fully remove the lid until you remove the ribbon cable attached to the front of the upper lid.
  • Do this by grabbing the upper lid from the sides and rotating it ninety degrees so it is perpendicular to the bottom lid.
  • Grab the ribbon cable and gently pull it out of its slot with your fingers.
  • The upper lid can now safely be removed from the bottom lid.
Aggiungi Commento
Locate the stepper motor. With the front of the scanner facing you, the motor is located at the top left. Disconnect the white connector from the vertical standing circuit board.
  • Locate the stepper motor. With the front of the scanner facing you, the motor is located at the top left.
  • Disconnect the white connector from the vertical standing circuit board.
Aggiungi Commento
Using a #2 Philips Screwdriver, unscrew the two 7.7mm screws holding the stepper motor in place. The stepper motor will become loose, but not completely free. The stepper motor will become loose, but not completely free.
  • Using a #2 Philips Screwdriver, unscrew the two 7.7mm screws holding the stepper motor in place.
  • The stepper motor will become loose, but not completely free.
Aggiungi Commento
Using tweezers gently remove the tread from the black gear on the stepper motor. The stepper motor will become completely free. The stepper motor will become completely free.
  • Using tweezers gently remove the tread from the black gear on the stepper motor.
  • The stepper motor will become completely free.
Aggiungi Commento
Conclusione
Cal Poly, Team 6-9, Regan Fall 2011 Membro di Cal Poly, Team 6-9, Regan Fall 2011
CPSU-REGAN-F11S6G9
2 Membri
11 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 1,363
