Salta al contenuto principale
Microsoft Zune HD Lower Rear Panel Replacement
Cosa ti serve
  1. Microsoft Zune HD Lower Rear Panel Replacement, Upper Rear Panel: passo 1, immagine 1 di 1
    • Remove the four Tri-Wing screws securing the upper rear panel to the inner chassis.
  2. Microsoft Zune HD Lower Rear Panel Replacement: passo 2, immagine 1 di 2 Microsoft Zune HD Lower Rear Panel Replacement: passo 2, immagine 2 di 2
    • Slightly rotate the top edge of the upper rear panel away from the Zune.
    • Lift the upper rear panel straight up off the black plastic lower rear panel.
  3. Microsoft Zune HD Lower Rear Panel Replacement, Lower Rear Panel: passo 3, immagine 1 di 2 Microsoft Zune HD Lower Rear Panel Replacement, Lower Rear Panel: passo 3, immagine 2 di 2
    • Insert a small Zune opening tool into the gap between the logic board and one side of the black plastic lower rear panel.
    • Carefully twist the Zune opening tool to pop the lower rear panel off the clips attaching it to the Zune.
    • Repeat this process for the other side of the lower rear panel.
  4. Microsoft Zune HD Lower Rear Panel Replacement: passo 4, immagine 1 di 1
    • Carefully slide the lower rear panel away from the Zune.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 3,112
